industry-department-solutions
- Overview
- Platform setup and administration
- Platform architecture
- Data Bridge onboarding overview
- Connecting a Peak-managed data lake
- Connecting a customer-managed data lake
- Creating an AWS IAM role for Data Bridge
- Connecting a Snowflake data warehouse
- Connecting a Redshift data warehouse (public connectivity)
- Connecting a Redshift data warehouse (private connectivity)
- Reauthorizing a Snowflake OAuth connection
- Using Snowflake with Peak
- SQL Explorer overview
- Roles and permissions
- User management
- Inventory management solution
- Commercial pricing solution
- Merchandising solution
Ce contenu n’est pas disponible dans la langue sélectionnée. La version en anglais est affichée à la place.
File formats and naming conventions
Supported file formats and naming conventions for file ingestion into Peak, including CSV formatting rules and compression recommendations.
This page lists the supported file formats and naming conventions for file ingestion.
Peak can ingest data from the following file formats:
There is no file size limit for uploads.
When possible, compress files with GZIP to reduce transfer size.
| Format | Notes |
| CSV | Recommended format for ingestion. |
| TXT | Must use supported delimiters. |
| JSON | Supported for file ingestion and feeds. |
| XML | Requires a root tag for parsing. |
| GZIP | Use .gz or .gzip extensions when compressing files. |
| XLSX | Supported if agreed in advance. |
When preparing CSV files for ingestion, follow these formatting guidelines:
- Use comma, tab, or pipe as the delimiter.
- Enclose all fields in double quotes.
- Replace delimiter characters in data values where possible.
- Use a header row for column names.
- Use a single worksheet if exporting from Excel.
- Use plain text character sets such as ASCII or UTF-8.
- Use CRLF for new lines and remove stray CR or LF characters.
File naming rules
Use these conventions when naming files for ingestion:
- Use alphanumeric characters and the following special characters:
! - _ . * ' ( ). - Avoid
#and+in file names. - Use lowercase file extensions.
- Use a timestamp when files are part of a recurring feed.
Data extract guidelines
Follow these best practices when extracting data for ingestion:
- Use a unique identifier for each row when data is updated.
- Keep date, datetime, and timestamp formats consistent.
- Trim leading and trailing spaces from text fields.
- Use incremental files after the initial load.
- Peak does not handle record deletion by default.
