industry-department-solutions
- Overview
- Platform setup and administration
- Platform architecture
- Data Bridge onboarding overview
- Connecting a Peak-managed data lake
- Connecting a customer-managed data lake
- Creating an AWS IAM role for Data Bridge
- Connecting a Snowflake data warehouse
- Connecting a Redshift data warehouse (public connectivity)
- Connecting a Redshift data warehouse (private connectivity)
- Reauthorizing a Snowflake OAuth connection
- Using Snowflake with Peak
- SQL Explorer overview
- Roles and permissions
- User management
- Inventory management solution
- Commercial pricing solution
- Merchandising solution
Ce contenu n’est pas disponible dans la langue sélectionnée. La version en anglais est affichée à la place.
Deleting files in Files
Delete files from the Peak data lake using Files, either from the action menu or the file details screen.
Remove files from your Peak data lake using Files. Deleting obsolete files helps maintain storage efficiency and keeps your data lake organized.
A file can be permanently deleted from its action menu or from the file details screen.
Prerequisites
Before deleting files, ensure you have the following:
- You have delete permissions for the target file.
Steps
Follow these steps to delete a file:
- In Peak, open Manage and select Files.
- Open the folder that contains the file.
- Delete the file using one of these options:
- Open the file action menu and select Delete.
- Open the file details screen and select Delete.
- Confirm the deletion. Deleted files cannot be recovered.
During deletion
While a file has Deleting status, other action menu items for that file are disabled until deletion completes.
Result
The file is permanently deleted from the data lake and cannot be recovered.
