industry-department-solutions
Supply Chain & Retail Solutions release notes
  • Inventory management solution release notes
    • 2026
      • October 2026
      • September 2026
      • August 2026
      • July 2026
      • June 2026
      • May 2026
      • April 2026
  • Commercial pricing solution release notes
  • Merchandising solution release notes
  • Rebuy & replenishment solution release notes
      • September 2026
Ce contenu n’est pas disponible dans la langue sélectionnée. La version en anglais est affichée à la place.
September 2026
September 2026 release notes for Rebuy & Replenishment in Automation Cloud.
September 28, 2026​
Data model updates​
  • Refreshed field descriptions for clarity.
September 24, 2026​
Data requirements tables: new Constraint column​
The dataset reference tables now use a single Constraint column in place of the previous Nullable and Notes columns. It shows each field's role and value rules together — Primary key, Unique, Foreign key to <dataset>, and whether the value is Non-null or Nullable — so a field's constraints are visible at a glance. Any field notes previously in the Notes column have been folded into the field descriptions.
September 16, 2026​
Data model updates​
  • September 28, 2026​
  • Data model updates​
  • September 24, 2026​
  • Data requirements tables: new Constraint column​
  • September 16, 2026​
