industry-department-solutions
Supply Chain & Retail Solutions release notes
  • Inventory management solution release notes
    • 2026
      • October 2026
      • September 2026
      • August 2026
      • July 2026
      • June 2026
      • May 2026
      • April 2026
  • Commercial pricing solution release notes
  • Merchandising solution release notes
  • Rebuy & replenishment solution release notes
Ce contenu n’est pas disponible dans la langue sélectionnée. La version en anglais est affichée à la place.
July 2026
July 2026 release notes for Inventory Management in Automation Cloud.
July 27, 2026​
Object-level data validations​
Schemas can now declare object-level validations — freshness and missing-data checks, plus foreign-key and unique-key toggles — through the new objectValidations field. See Object-level validations.
July 24, 2026​
Historical data ingestion​
The Historical data ingestion reference script for one-shot bulk loads has been expanded based on field experience:
  • Multi-table single run — load every table in your solution in one invocation, in foreign-key dependency order, instead of running the script once per table.
  • Run modes — a --mode historical (APPEND, parallel) or --mode daily (UPSERT, serial) switch, plus --table to load a single table and --dry-run to validate files without writing.
  • Wider null and encoding handling — NULL, NA, and N/A are recognized as null (case-insensitively) alongside empty strings and \N, and non-UTF-8 exports are decoded via a utf-8-sig → cp1252 → latin-1 fallback.
  • Consolidated failed-row report — rejected rows are written both to a crash-safe log and to a single JSON file per table for quick triage.
  • Post-run archive — an optional --archive flag moves loaded files into a dated archive folder once each table completes.
July 6, 2026​
Inventory Management schema updated​
The Inventory Management data schema now follows the latest standard schema, with endpoint specifications using generic {prefix}/{suffix} placeholders, consistent with the other Supply Chain & Retail schemas.
This release also adds a new Forecast resource for demand forecast values and updates the Stock, Sales, and Transfers schemas: stock is now reported as daily opening and closing levels, sales units as a decimal quantity, and transfers include expected and actual delivery dates alongside departure dates. The updated_at column has been removed from all inventory tables.
  • July 27, 2026​
  • Object-level data validations​
  • July 24, 2026​
  • Historical data ingestion​
  • July 6, 2026​
  • Inventory Management schema updated​
