industry-department-solutions
Supply Chain & Retail Solutions release notes
  • Inventory management solution release notes
    • 2026
      • October 2026
      • September 2026
      • August 2026
      • July 2026
      • June 2026
      • May 2026
      • April 2026
  • Commercial pricing solution release notes
      • October 2026
      • September 2026
      • August 2026
      • July 2026
      • June 2026
      • May 2026
      • April 2026
  • Merchandising solution release notes
  • Rebuy & replenishment solution release notes
Ce contenu n’est pas disponible dans la langue sélectionnée. La version en anglais est affichée à la place.
August 2026
August 2026 release notes for Commercial Pricing in Automation Cloud.
August 26, 2026​
New: alerts for failing object-level validations​
A failing object-level validation can now notify a Slack channel or an email group, so a data quality problem reaches your team without anyone watching the dashboard. Alert channels can be registered once per tenant through /api/v2/alert-configs and named in a new alerts array on a freshness or missing_data_validation entry. The reserved name __ALL__ notifies every channel registered for the tenant.
Alerts are sent only when a check finishes in a failed or error state, and the run report lists the channels notified for each result in alerts_sent. A channel that cannot be reached does not fail the validation run. See Data quality alerts.
August 12, 2026​
Renamed: add-object replaces custom-table​
The endpoint for adding a custom object to a solution is now POST /api/v2/schema/add-object, replacing POST /api/v2/schema/custom-table. The new name pairs with POST /api/v2/schema/{objectName}/add-attribute — one adds a table, the other adds a column. Request and response bodies are unchanged, and the previous custom-table path continues to work, though it is deprecated and may be removed in a future release; add-object is the recommended alternative going forward. See Add a custom object.
Corrected: primaryKeys is required when adding a custom object​
The Add a custom object payload reference previously listed primaryKeys as optional. It has always been required — a request without a non-empty primaryKeys array is rejected with 400 Bad Request, and every name in it must match a column declared in columns.
August 10, 2026​
Bulk CSV upload​
You can now ingest a large dataset by uploading a CSV (or .csv.gz) file directly to an existing table, instead of sending rows as JSON. Uploads are scanned for malware, validated against the schema per row, and processed asynchronously — poll the returned requestId for status and success/failure counts. See Bulk CSV upload.
Object validations in the Data Quality Dashboard​
The Data Quality Dashboard now surfaces object-level validation results alongside the existing row-level metrics — freshness age vs. threshold, missing-data gaps, and per-period shortfall, with per-table drill-down. See Object-level validations.
