industry-department-solutions
- Overview
- API Resources
Ce contenu n’est pas disponible dans la langue sélectionnée. La version en anglais est affichée à la place.
Stock Extra
stock_extra API resource capturing inventory levels broken down by product variant, used alongside sale_extra for variant-level stock tracking.
The stock_extra resource captures inventory levels broken down by product variant. Use it alongside sale_extra when your sales data tracks variants and you need matching variant-level stock counts. Mirrors the structure of stock but adds product_variant to the primary key.
Resource Endpoint
/api/v2/ingest/object/{prefix}STOCK_EXTRA{suffix}
Supported Methods
| Method | Return Type | Description |
| POST | Response | Ingest (create/update) stock-extra records via UPSERT operation |
Request Headers
| Header | Required | Description |
Authorization | Yes | Your Personal Access Token (PAT) from platform.peak.ai |
Content-Type | Yes | Must be application/json |
Properties
Primary Keys
- product_id (string) - Foreign key reference to products
- location_id (string) - Foreign key reference to locations
- product_variant (string) - Variant identifier (size / colour / pack / etc.)
- stock_date_at (date) - Date for the stock snapshot
Attributes
About Required + Nullable: every attribute key must appear in each payload (Required: Yes). Nullable: Yes means the value can be null when you don't have data; Nullable: No means a non-null value is required. See Schema definition structure for the underlying rules.
| Attribute | Data Type | Required | Nullable | Description |
product_id | string | Yes | No | Product identifier (Primary Key, Foreign Key) |
location_id | string | Yes | No | Location identifier (Primary Key, Foreign Key) |
product_variant | string | Yes | No | Variant of the product (e.g., size:L, colour:red). Part of the Primary Key. |
stock_date_at | date | Yes | No | Stock snapshot date (Primary Key) |
created_at | timestamp | Yes | Yes | Timestamp when the record was created |
stock_id | string | Yes | Yes | Alternative stock record identifier |
stock_units | integer | Yes | No | Number of units in stock for this variant |
updated_at | timestamp | Yes | Yes | Timestamp when the record was last updated |
Relationships
Outbound References
None
Inbound References
- product - Foreign key
product_idreferences product - location - Foreign key
location_idreferences location
JSON Representation
"solutionName": "MP_OOTB",
"data": [
"product_id": "PROD-001",
"location_id": "LOC-UK-001",
"product_variant": "size:L",
"stock_date_at": "2025-01-28",
"created_at": "2025-01-28T00:00:00Z",
"stock_id": "STK-2025-001",
"stock_units": 120,
"updated_at": "2025-01-28T10:00:00Z"
"operationType": "UPSERT"
"data": [
"stock_units": 120,
Example Request
curl -X POST \
'https://ingestion.peak.ai/api/v2/objects/MP_STOCK_EXTRA_OOTB' \
-d '{
"data": [
"stock_units": 120,
curl -X POST \
-d '{
"data": [
"stock_units": 120,
Important Notes
- When to use vs
stock: send rows to stock if you don't track variant-level inventory; send tostock_extrawhen variant-level stock is required. Don't double-count by sending the same physical inventory to both. - Variant convention: keep the
product_variantstring consistent with what you use in sale_extra — downstream consumers join the two on the same (product_id,location_id,product_variant) tuple. - Foreign Key Dependencies: Requires valid
product_idandlocation_idto exist in their respective tables. - Custom Attributes: Additional custom attributes can be added using the
/STOCK_EXTRA/add-attributeendpoint. - Data Validation: All attributes are validated according to their defined data types.
Related Resources
- stock - Variant-less stock levels
- sale_extra - Variant-level sales (paired use)
- product - Product information
- location - Stock location
