industry-department-solutions
Ce contenu n’est pas disponible dans la langue sélectionnée. La version en anglais est affichée à la place.
Suppliers
Suppliers API resource representing external vendors in the procurement process, including minimum order quantities and values for inventory planning.
Overview​
The Suppliers resource represents the external vendors and supply sources used in the procurement process. Each record captures a supplier's identity and the ordering constraints they impose, such as minimum order quantities and minimum order values. Suppliers are referenced by other resources as the source_id field to establish supply relationships.
Resource Endpoint​
/api/v2/ingest/object/{prefix}SUPPLIERS{suffix}
Supported Methods​
MethodReturn TypeDescription
POSTResponseIngest (create/update) Suppliers records via UPSERT operation
Request Headers​
HeaderRequiredDescription
AuthorizationYesYour Personal Access Token (PAT) from platform.peak.ai
Content-TypeYesMust be application/json
Properties​
Primary Keys​
  • supplier_id (string) - Unique identifier for the supplier. Used as the primary key for deduplication and UPSERT operations.
Attributes​
AttributeData TypeRequiredDescription
supplier_idstringYesUnique identifier for the supplier
supplier_namestringYesHuman-readable name of the supplier
minimum_order_quantityintegerNoThe minimum number of units that must be ordered from this supplier
moq_unit_of_measurestringNoThe unit of measure applicable to the minimum order quantity (for example, "units", "cases")
minimum_order_valueintegerNoThe minimum monetary value that must be met per order from this supplier
mov_unit_of_measurestringNoThe currency or unit applicable to the minimum order value (for example, "GBP", "USD")
Relationships​
Outbound References​
The suppliers resource does not reference any other resource as a foreign key.
Inbound References​
The following resources reference suppliers via source_id:
  • order_parameters — source_id → suppliers.supplier_id
  • purchase_orders — source_id → suppliers.supplier_id
  • transfers — source_id → suppliers.supplier_id
JSON Representation​
  "solutionName": "INV_OOTB",
  "data": [
      "supplier_id": "SUP-001",
      "supplier_name": "Global Parts Ltd",
      "minimum_order_quantity": 100,
      "moq_unit_of_measure": "units",
      "minimum_order_value": 500,
      "mov_unit_of_measure": "GBP"
  "operationType": "UPSERT"
  "data": [
Example Request​
curl -X POST \
  'https://ingestion.peak.ai/api/v2/objects/INV_SUPPLIERS_OOTB' \
  -d '{
    "data": [
curl -X POST \
  -d '{
    "data": [
Important Notes​
  • supplier_id is the primary key, used for deduplication and UPSERT operations.
  • The supplier_id value is used as the source_id field in related resources such as Purchase Orders, Order Parameters, and Transfers.
  • minimum_order_quantity and minimum_order_value are optional. When omitted, the system assumes no minimum constraints apply.
  • Ensure moq_unit_of_measure and mov_unit_of_measure are populated when their corresponding minimum values are provided.
