industry-department-solutions
Ce contenu n’est pas disponible dans la langue sélectionnée. La version en anglais est affichée à la place.
Stock
Stock API resource representing daily opening and closing inventory levels per product-location, enabling time-series analysis of inventory positions across the supply chain.
Overview​
The Stock resource represents daily on-hand inventory levels for a given product at a given location. Each record captures the opening and closing stock quantities on a specific date, enabling time-series analysis of inventory positions across the supply chain network.
Resource Endpoint​
/api/v2/ingest/object/{prefix}STOCK_DAILY{suffix}
Supported Methods​
MethodReturn TypeDescription
POSTResponseIngest (create/update) Stock records via UPSERT operation
Request Headers​
HeaderRequiredDescription
AuthorizationYesYour Personal Access Token (PAT) from platform.peak.ai
Content-TypeYesMust be application/json
Properties​
Primary Keys​
  • product_id (string) - Unique identifier for the product. Part of the composite primary key.
  • location_id (string) - Unique identifier for the location. Part of the composite primary key.
  • day_date (date) - The calendar date for which the stock level is recorded. Part of the composite primary key.
Attributes​
AttributeData TypeRequiredDescription
product_idstringYesUnique identifier for the product
location_idstringYesUnique identifier for the location
day_datedateYesThe date of the stock snapshot, in YYYY-MM-DD format
opening_stockintegerYesQuantity of the product on hand at the start of the given date
closing_stockintegerYesQuantity of the product on hand at the end of the given date
Relationships​
Outbound References​
The stock_daily resource does not reference any downstream resources as foreign keys.
Inbound References​
The following resources are referenced by stock_daily:
  • products — product_id → products.product_id
  • locations — location_id → locations.location_id
JSON Representation​
  "solutionName": "INV_OOTB",
  "data": [
      "product_id": "PROD-001",
      "location_id": "LOC-001",
      "day_date": "2025-01-15",
      "opening_stock": 520,
      "closing_stock": 500
  "operationType": "UPSERT"
  "data": [
Example Request​
curl -X POST \
  'https://ingestion.peak.ai/api/v2/objects/INV_STOCK_DAILY_OOTB' \
  -d '{
    "data": [
curl -X POST \
  -d '{
    "data": [
Important Notes​
  • product_id, location_id, and day_date together form the composite primary key. All three fields must be provided on every record.
  • day_date must be in YYYY-MM-DD format.
  • opening_stock and closing_stock must be non-negative integers. A value of 0 is valid and indicates no stock on hand.
  • product_id must correspond to an existing record in the Products resource.
  • location_id must correspond to an existing record in the Locations resource.
  • Records are ingested via UPSERT: an existing record with matching primary keys will be updated; otherwise a new record is inserted.
