industry-department-solutions
- Overview
- API Resources
Ce contenu n’est pas disponible dans la langue sélectionnée. La version en anglais est affichée à la place.
Product Pricing Daily
product_pricing_daily API resource representing daily pricing snapshots per product-location combination, including selling prices, costs, and list prices.
The product_pricing_daily resource represents daily pricing snapshots for products at specific locations. This resource stores time-series pricing data including selling prices, costs, and list prices.
Resource Endpoint
/api/v2/ingest/object/{prefix}PRODUCT_PRICING_DAILY{suffix}
Supported Methods
| Method | Return Type | Description |
| POST | Response | Ingest (create/update) daily pricing records via UPSERT operation |
Request Headers
| Header | Required | Description |
Authorization | Yes | Your Personal Access Token (PAT) from platform.peak.ai |
Content-Type | Yes | Must be application/json |
Properties
Primary Keys
- location_id (string) - Foreign key reference to locations
- pricing_at (timestamp) - Timestamp for the pricing snapshot
- product_id (string) - Foreign key reference to products
Attributes
About Required + Nullable: every attribute key must appear in each payload (Required: Yes). Nullable: Yes means the value can be null when you don't have data; Nullable: No means a non-null value is required. See Schema definition structure for the underlying rules.
| Attribute | Data Type | Required | Nullable | Description |
location_id | string | Yes | No | Location identifier (Primary Key, Foreign Key) |
pricing_at | timestamp | Yes | No | Pricing snapshot timestamp (Primary Key) |
product_id | string | Yes | No | Product identifier (Primary Key, Foreign Key) |
selling_price | float | Yes | No | Current selling price |
unit_cost_price | float | Yes | No | Cost per unit |
unit_list_price | float | Yes | No | List price per unit |
quote_stage | string | Yes | Yes | Pricing stage or lifecycle status |
created_at | timestamp | Yes | Yes | Timestamp when the record was created |
updated_at | timestamp | Yes | Yes | Timestamp when the record was last updated |
Relationships
Outbound References
None
Inbound References
- product - Foreign key
product_idreferences product - location - Foreign key
location_idreferences location
JSON Representation
"solutionName": "MP_OOTB",
"data": [
"location_id": "LOC-UK-001",
"pricing_at": "2025-01-28T00:00:00Z",
"product_id": "PROD-001",
"selling_price": 199.99,
"unit_cost_price": 120.00,
"unit_list_price": 249.99,
"quote_stage": "active",
"created_at": "2025-01-28T01:00:00Z",
"updated_at": "2025-01-28T10:00:00Z"
"operationType": "UPSERT"
"data": [
Example Request
curl -X POST \
'https://ingestion.peak.ai/api/v2/objects/MP_PRODUCT_PRICING_DAILY_OOTB' \
-d '{
"data": [
curl -X POST \
-d '{
"data": [
Important Notes
- Foreign Key Dependencies: Requires valid
product_idandlocation_idto exist in their respective tables - Time-Series Data: Captures daily pricing snapshots for trend analysis
- Multi-Price Tracking: Stores selling price, cost, and list price for margin analysis
- Location-Specific: Prices can vary by location
- Custom Attributes: Additional custom attributes can be added using the
/PRODUCT_PRICING_DAILY/add-attributeendpoint - Data Validation: All attributes are validated according to their defined data types
