industry-department-solutions
- Overview
- API Resources
Ce contenu n’est pas disponible dans la langue sélectionnée. La version en anglais est affichée à la place.
Manufacturing Orders
Manufacturing Orders API resource representing production work orders governing internal manufacture of products at factory locations.
The Manufacturing Orders resource represents production work orders that govern the internal manufacture of products at factory locations. Each record tracks a single manufacturing order through its full lifecycle, from the initial planned quantities and scheduled dates through to actual production start and end times, units produced, and current status.
Resource Endpoint
/api/v2/ingest/object/{prefix}MANUFACTURING_ORDERS{suffix}
Supported Methods
| Method | Return Type | Description |
| POST | Response | Ingest (create/update) Manufacturing Orders records via UPSERT operation |
Request Headers
| Header | Required | Description |
Authorization | Yes | Your Personal Access Token (PAT) from platform.peak.ai |
Content-Type | Yes | Must be application/json |
Properties
Primary Keys
- product_id (string) - Unique identifier for the product being manufactured. Part of the composite primary key.
- location_id (string) - Unique identifier for the factory location. Part of the composite primary key.
- order_number (string) - Unique identifier for the manufacturing order. Part of the composite primary key.
Attributes
| Attribute | Data Type | Required | Description |
product_id | string | Yes | Unique identifier for the product being manufactured |
location_id | string | Yes | Unique identifier for the factory or production site |
order_number | string | Yes | Unique identifier for this manufacturing order |
source_id | string | Yes | Identifier of the production line or internal source initiating the order |
ordered_at | timestamp | Yes | Datetime when the manufacturing order was created |
ordered_units | integer | Yes | Number of units planned for production |
expected_start_date | timestamp | Yes | Planned datetime for production to begin |
actual_start_date | timestamp | No | Actual datetime production commenced |
expected_end_date | timestamp | Yes | Planned datetime for production to be completed |
actual_end_date | timestamp | No | Actual datetime production was completed |
produced_units | integer | No | Number of units actually produced |
status | string | No | Current status of the manufacturing order (for example, "scheduled", "in_progress", "completed") |
Relationships
Outbound References
The manufacturing_orders resource does not reference any downstream resources as foreign keys.
Inbound References
The following resources are referenced by manufacturing_orders:
- products —
product_id→products.product_id - locations —
location_id→locations.location_id
JSON Representation
"solutionName": "INV_OOTB",
"data": [
"order_number": "MO-2025-001",
"product_id": "PROD-001",
"location_id": "LOC-001",
"source_id": "LINE-001",
"ordered_at": "2025-01-05 08:00:00",
"ordered_units": 500,
"expected_start_date": "2025-01-10 06:00:00",
"actual_start_date": "2025-01-10 06:30:00",
"expected_end_date": "2025-01-12 18:00:00",
"actual_end_date": "2025-01-12 17:45:00",
"produced_units": 498,
"status": "completed"
"operationType": "UPSERT"
"data": [
Example Request
curl -X POST \
'https://ingestion.peak.ai/api/v2/objects/INV_MANUFACTURING_ORDERS_OOTB' \
-d '{
"data": [
curl -X POST \
-d '{
"data": [
Important Notes
product_id,location_id, andorder_numbertogether form the composite primary key. All three fields must be provided on every record.expected_start_dateandexpected_end_dateare required planned dates; theiractual_counterparts are optional and should be populated as production progresses.produced_unitsandactual_start_date/actual_end_dateshould be updated incrementally as the order progresses.- The
location_idfor a manufacturing order should reference a location whereis_factoryis set totrue. - All timestamps must be provided in
YYYY-MM-DD HH:MM:SSformat.
