industry-department-solutions
Ce contenu n’est pas disponible dans la langue sélectionnée. La version en anglais est affichée à la place.
List Price
list_price API resource representing standard product list prices in specific regions and price lists before discounts or negotiations.
Overview​
The list_price resource represents list prices for products in specific regions and price lists. This resource stores the standard pricing before any discounts or negotiations.
→ For business context (purpose, usage notes, how this resource is used in the solution), see List price dataset in the User Guide.
Resource Endpoint​
/api/v2/ingest/object/{prefix}LIST_PRICE{suffix}
Supported Methods​
MethodReturn TypeDescription
POSTResponseIngest (create/update) list price records via UPSERT operation
Request Headers​
HeaderRequiredDescription
AuthorizationYesYour Personal Access Token (PAT) from platform.peak.ai
Content-TypeYesMust be application/json
Properties​
Primary Keys​
  • product_id (string) - Foreign key reference to products
  • region_id (string) - Foreign key reference to regions
  • price_list_id (string) - Identifier for the price list
  • updated_at (datetime) - Timestamp of when the record was last updated
Attributes​
About Required + Nullable: every attribute key must appear in each payload (Required: Yes). Nullable: Yes means the value can be null when you don't have data; Nullable: No means a non-null value is required. See Schema definition structure for the underlying rules.
AttributeData TypeRequiredNullableDescription
product_idstringYesNoUnique identifier for each product. Used to join product metadata to quotations and sales for model training and guardrails.
region_idstringYesNoRegion identifier (Primary Key, Foreign Key)
price_list_idstringYesNoPrice list identifier (Primary Key)
updated_atdatetimeYesYesTimestamp when the record was updated. Used to identify the most up-to-date data in the UI and when optimising prices. For model training, used to match the list price to the date of each quote.
list_pricefloatYesYesList price for the product. Used to calculate the discount applied to all quotations and sales orders for model training and optimising prices.
Relationships​
Outbound References​
None
Inbound References​
  • product - Foreign key product_id references product
  • region - Foreign key region_id references region
JSON Representation​
  "solutionName": "QP_OOTB",
  "data": [
      "product_id": "PROD-001",
      "region_id": "EMEA-UK",
      "price_list_id": "PL-STD-2025",
      "updated_at": "2025-01-28T10:00:00Z",
      "list_price": 199.99
  "operationType": "UPSERT"
  "data": [
Example Request​
curl -X POST \
  'https://ingestion.peak.ai/api/v2/objects/QP_LIST_PRICE_OOTB' \
  -d '{
    "data": [
curl -X POST \
  -d '{
    "data": [
Important Notes​
  • Foreign Key Dependencies: Requires valid product_id and region_id to exist in their respective tables
  • Multiple Price Lists: The price_list_id allows for different pricing structures (e.g., standard, premium, volume)
  • Custom Attributes: Custom attributes can be added with POST /api/v2/schema/{objectName}/add-attribute, where {objectName} is this table's fully qualified warehouse name ({prefix}LIST_PRICE{suffix} — for example, QP_LIST_PRICE_OOTB), as returned by Describe a solution's schema
  • Data Validation: All attributes are validated according to their defined data types
