industry-department-solutions
Ce contenu n’est pas disponible dans la langue sélectionnée. La version en anglais est affichée à la place.
Product Extra
Product Extra API resource for storing custom key-value attributes against an Inventory Management product, enabling schema extensibility without core changes.
Overview​
The Product Extra resource provides a flexible mechanism for storing additional, custom attributes against a product that are not captured in the core Products schema. Each record represents a single key-value attribute pair for a product, enabling extensibility without schema changes.
Resource Endpoint​
/api/v2/ingest/object/{prefix}PRODUCT_EXTRA{suffix}
Supported Methods​
MethodReturn TypeDescription
POSTResponseIngest (create/update) Product Extra records via UPSERT operation
Request Headers​
HeaderRequiredDescription
AuthorizationYesYour Personal Access Token (PAT) from platform.peak.ai
Content-TypeYesMust be application/json
Properties​
Primary Keys​
  • product_id (string) - Unique identifier for the product this attribute belongs to. Part of the composite primary key.
  • product_extra_id (string) - Unique identifier for this specific extra attribute record. Part of the composite primary key.
Attributes​
AttributeData TypeRequiredDescription
product_idstringYesUnique identifier for the product this attribute belongs to
product_extra_idstringYesUnique identifier for this extra attribute record
product_extra_attributestringYesThe name of the custom attribute (for example, "weight_kg", "colour")
product_extra_valuestringNoThe value of the custom attribute (for example, "2.5", "blue")
created_attimestampYesTimestamp when this extra attribute record was first created
Relationships​
Outbound References​
The product_extra resource does not reference any downstream resources as foreign keys.
Inbound References​
The following resource is referenced by product_extra:
  • products — product_id → products.product_id
JSON Representation​
  "solutionName": "INV_OOTB",
  "data": [
      "product_id": "PROD-001",
      "product_extra_id": "ATTR-001",
      "product_extra_attribute": "weight_kg",
      "product_extra_value": "2.5",
      "created_at": "2025-01-10 08:00:00"
  "operationType": "UPSERT"
  "data": [
Example Request​
curl -X POST \
  'https://ingestion.peak.ai/api/v2/objects/INV_PRODUCT_EXTRA_OOTB' \
  -d '{
    "data": [
curl -X POST \
  -d '{
    "data": [
Important Notes​
  • product_id and product_extra_id together form the composite primary key. Both fields must be provided on every record.
  • product_extra_attribute is required and defines the name of the custom attribute being stored.
  • product_extra_value is optional; it may be omitted or set to null if no value is currently available for the attribute.
  • All attribute values are stored as strings, regardless of the underlying data type they represent.
  • product_id must correspond to an existing record in the Products resource.
  • All timestamps must be provided in YYYY-MM-DD HH:MM:SS format.
