industry-department-solutions
Ce contenu n’est pas disponible dans la langue sélectionnée. La version en anglais est affichée à la place.
Competitor Price
competitor_price API resource for tracking competitor pricing data per product-region combination over time in Supply Chain & Retail Solutions.
Overview​
The competitor_price resource tracks competitor pricing data for specific product-region combinations over time. This competitive intelligence enables comparison against your own pricing to inform pricing strategy and competitive positioning decisions. This resource is optional and only needs to be ingested if competitive pricing analysis is required.
→ For business context (purpose, usage notes, how this resource is used in the solution), see Competitor prices dataset in the User Guide.
Resource Endpoint​
/api/v2/ingest/object/{prefix}COMPETITOR_PRICE{suffix}
Supported Methods​
MethodReturn TypeDescription
POSTResponseIngest (create/update) competitor price records via UPSERT operation
Request Headers​
HeaderRequiredDescription
AuthorizationYesYour Personal Access Token (PAT) from platform.peak.ai
Content-TypeYesMust be application/json
Properties​
Primary Keys​
  • product_id (string) - Foreign key reference to products
  • region_id (string) - Foreign key reference to regions
  • updated_at (datetime) - Timestamp of when the record was last updated
Attributes​
About Required + Nullable: every attribute key must appear in each payload (Required: Yes). Nullable: Yes means the value can be null when you don't have data; Nullable: No means a non-null value is required. See Schema definition structure for the underlying rules.
AttributeData TypeRequiredNullableDescription
product_idstringYesNoProduct identifier (Primary Key, Foreign Key)
region_idstringYesNoRegion identifier (Primary Key, Foreign Key)
updated_atdatetimeYesYesLast update timestamp (Primary Key)
competitor_pricefloatYesYesCompetitor's price for this product in this region
Relationships​
Outbound References​
None
Inbound References​
  • product - Foreign key product_id references product
  • region - Foreign key region_id references region
JSON Representation​
  "solutionName": "QP_OOTB",
  "data": [
      "product_id": "PROD-001",
      "region_id": "EMEA-UK",
      "updated_at": "2025-01-28T10:00:00Z",
      "competitor_price": 149.99
  "operationType": "UPSERT"
  "data": [
Example Request​
curl -X POST \
  'https://ingestion.peak.ai/api/v2/objects/QP_COMPETITOR_PRICE_OOTB' \
  -d '{
    "data": [
curl -X POST \
  -d '{
    "data": [
Important Notes​
  • Foreign Key Dependencies: Requires valid product_id and region_id to exist in their respective tables
  • Pricing Intelligence: Used to compare your pricing against competitor offerings
  • Custom Attributes: Custom attributes can be added with POST /api/v2/schema/{objectName}/add-attribute, where {objectName} is this table's fully qualified warehouse name ({prefix}COMPETITOR_PRICE{suffix} — for example, QP_COMPETITOR_PRICE_OOTB), as returned by Describe a solution's schema
  • Data Validation: All attributes are validated according to their defined data types
