industry-department-solutions
Healthcare Solutions user guide
  • Overview
    • About Healthcare solutions
  • Medical Record Summarization
Ce contenu n’est pas disponible dans la langue sélectionnée. La version en anglais est affichée à la place.
A template's lifecycle
Template lifecycle in Medical Record Summarization, covering the Draft, Published, Deployed, and Archived statuses and version history behavior.
A template defines the structure of the AI-generated clinical summary: which sections to include, what type of output each section produces, and how the AI is instructed to populate each section. Templates progress through three statuses before they can process records in production, can be archived once they are no longer needed, and every change to a template is preserved as a numbered version.
Template statuses​
Templates move through a defined lifecycle from creation to production.
StatusDescription
DraftThe template is being built or modified. It cannot be connected to a deployment or used to process records automatically. Draft templates can be tested using manual batch runs.
PublishedThe template has been reviewed and is ready for production use. A published template appears in the Deployments page and can be connected to an Orchestrator trigger. Publishing does not process records - it signals readiness.
DeployedThe template is connected to an active deployment and is processing records automatically on a configured schedule.
ArchivedThe template has been retired. Archived templates are hidden from the Templates list unless Archived is selected in the Status filter. Archiving is reversible.
A published template can be returned to draft by editing it - any saved edit creates a new draft version. A deployed template can be paused or stopped from the Deployments page without changing the template's published status.
Archive and restore a template​
Archive a template you no longer need from the … menu on its row in the Templates list. Archiving takes effect immediately, with no confirmation prompt, and the template leaves the default list view.
To bring it back, select Archived in the Status filter to display archived templates, then select Restore from the … menu on the template's row. The template returns to Draft status. The … menu on an archived template offers only Duplicate, Restore, and Delete.
Template versioning​
Every time a template is saved in the editor, the system creates a new numbered version. Version numbers are sequential and permanent. No version is ever overwritten or deleted when a new version is saved - the full history is always accessible.
The version history is accessible from Version history in the … overflow menu in the template editor. Each entry shows who made the change and when. This audit trail supports compliance requirements in regulated healthcare environments.
When a template is deployed, the deployment is connected to a specific version. If the template is later edited and a new version is published, the deployment continues using the previously connected version until explicitly updated.
Templates list​
The Templates page displays aggregate usage metrics across all templates, followed by the template list.
Stats panel​
Four metrics appear at the top of the page, scoped to the selected time period using the All time filter.
MetricDescription
Summaries generatedTotal number of summaries produced across all templates
Pages summarizedTotal pages processed across all summarization runs
Time savedEstimated time saved compared to manual review, based on average document length
Avg. review timeAverage time reviewers spent completing a review
Template list columns​
ColumnDescription
TemplateThe template name and current version number
StatusDraft, Published, or Deployed
SummariesNumber of summaries generated by this template
FeedbackNumber of reviewer overrides and policy decision verdicts recorded against this template
Last updated byThe user who last saved a change to the template
Date createdThe date the template was created
Last runThe date of the most recent summarization run; displays - if no run has occurred
Filters​
FilterDescription
SearchFree-text search across template names
StatusMulti-select filter for template status. Defaults to Deployed, Published, and Draft. Archived is not selected by default, so archived templates are hidden until you select it.
Updated byFilter by the user who last updated the template; defaults to All
Template detail view​
Selecting a published or deployed template from the list opens the template detail view. The detail view provides three tabs: Overview, Runs, and Overrides. The Runs and Overrides tabs carry a count badge.
Overview tab​
The Overview tab provides a consolidated view of template quality and recent activity.
Template quality at a glance​
An AI-generated summary interprets the override data for the selected time period and produces a headline and a brief description of where reviewer edits are concentrated. The time period is controlled by the date range selector (for example, Last 90 days).
The summary is accompanied by a line chart that plots overrides, documents reviewed, and version updates over the selected period.
Until enough reviews have accumulated, the panel reports Not enough reviews yet and names how many summaries were reviewed in the selected period.
Stats panel​
MetricDescription
Completion ratePercentage of this template's summaries that reached a completion status, displayed as a circular gauge with the number reviewed beneath it
Average review timeAverage time between a reviewer opening a summary and completing the review
SummariesTotal summaries generated by this template
OverridesTotal override actions recorded across all summaries for this template
Sections needing attention​
Lists the template sections that have received the most overrides, with the override count and override rate (as a percentage of total reviewed summaries) for each section. When no overrides have been recorded, the panel reports No section overrides recorded yet.
Recent activity​
Lists the most recent runs associated with this template, showing the batch name, status, and document count.
Runs tab​
Displays all summarization runs associated with this template. Each row in the list represents one batch run.
ColumnDescription
NameThe name of the run, generated automatically from the run type and date
SourceHow the run was triggered: Manual upload or the deployment name for scheduled runs
StatusThe current run status: Completed, In progress, Failed
DocumentsNumber of documents processed in the run
DurationTotal elapsed time from run start to completion
Created byThe user or system entity that triggered the run
DateThe date and time the run was started
DeploymentThe deployment associated with the run, if applicable
Runs can be filtered by Status and Source using the dropdowns in the tab header.
Overrides tab​
Displays all reviewer overrides recorded against this template, along with the policy decision feedback reviewers left on Policy sections, and AI-generated recommendations for improving the template based on override patterns. See Template overrides and recommendations for details.
Template overrides and recommendations​
The Overrides tab surfaces the full history of reviewer feedback - both section overrides and policy decision verdicts - and uses AI analysis of the section overrides to identify recurring patterns and suggest targeted improvements to the template's section instructions.
When no feedback has been recorded, the tab reports No feedback has been recorded for this template yet.
Stats panel​
MetricDescription
Completion ratePercentage of this template's summaries that reached a completion status across the selected time period
OverridesTotal number of overrides recorded
RecommendationsNumber of active AI-generated recommendations
Filters​
FilterDescription
All timeDate range filter scoping the stats and list
SectionFilter overrides by template section name
ReasonFilter by the reason selected by the reviewer
VersionFilter by the template version active at the time of the override
When the AI identifies a pattern across multiple overrides in the same section, it generates a recommendation card. Each card includes the section name, a descriptive title, a badge naming the category of problem found (for example, Prompt gap), and a description of the issue. The priority badge appears once the recommendation is applied to the template editor, not on the card itself.
Each recommendation card shows the number of related overrides and the template version it applies to. Two actions are available:
ActionDescription
ApplyOpens the template editor with the recommendation pre-loaded as an inline AI suggestion on the relevant section
IgnoreDismisses the recommendation without making changes
To trigger a fresh analysis of accumulated feedback, select Analyze overrides. Analysis runs on demand each time you select it, and only evaluates feedback on summaries that have reached a completion status. The analysis looks for patterns rather than individual events, so a single override on a section does not produce a recommendation. Analysis covers section overrides on Summary output only. Policy decision feedback is recorded but is not yet analyzed.
When no recommendations exist, the panel reports No recommendations yet.
Override list​
The table lists each individual override record.
ColumnDescription
TypeThe output type of the section the feedback was left on: Summary, Q+A, or Policy
SectionThe section of the template where the override was made
SummaryThe filename of the source document; select to open the review detail
ReasonThe reason selected by the reviewer when submitting the override
Review verdictThe completion status the review reached
WhenDate and time the override was submitted
ReviewerThe email address of the reviewer who submitted the override
Shared with UiPathWhether the reviewer opted to share the feedback data with UiPath
VersionThe template version used when the summary was generated
Each row is expandable. Expanding a row reveals additional detail about the override, including the Feedback for the agent text the reviewer entered when submitting it.
Template editor AI suggestions​
When a recommendation from the Overrides tab has been applied to the template editor, an inline AI suggestion panel appears on the relevant section. The panel shows a priority badge (High, Medium, or Low), a title, and a description of the issue.
Under Recommended prompt change, the panel shows the proposed instructions as a diff: text to be removed is struck through and text to be added is highlighted.
Select Apply suggestion to accept the suggestion and replace the section instructions, Dismiss to discard it, or View feedback to open the overrides it was derived from.
