industry-department-solutions
Healthcare Solutions user guide
  • Overview
    • About Healthcare solutions
  • Medical Record Summarization
Ce contenu n’est pas disponible dans la langue sélectionnée. La version en anglais est affichée à la place.
About policies
Policy Engine in Medical Record Summarization, which turns a policy document into a decision model that evaluates clinical records against prescriptive rules.
A policy turns a written document - a standard operating procedure, a scoring methodology, or a list of rules - into a decision model that Medical Record Summarization can apply to a clinical record. Where a Summary section asks the AI to narrate what a record contains, a policy asks it to assess the record against prescriptive criteria and return a defined outcome.
Common policy documents include payer coverage policies, hospital or health system protocols, and medical coding guidelines. Any document that carries rules or criteria that must be evaluated consistently and accurately can serve as a policy document.
How a policy is structured​
A policy has three parts, and each depends on the one before it.
PartWhat it holds
Policy documentThe source PDF. It is the authority for every rule, and remains viewable alongside the summary during review.
Decision profileThe question the AI answers about the document and the outcomes it may choose from. Reusable across policies, and a single policy document can be referenced by more than one profile.
Decision modelThe rule tree extracted from the document, expressed as nested rule groups and conditions. Versioned.
When you create a policy, the AI reads the policy document and builds the decision model from it. That run takes a few minutes. You can then review the generated rule tree and refine it before it is used in production.
Decision profiles​
A decision profile pins down what question is being asked and what answers are permitted. Because a profile is reusable, any number of policies covering the same determination can share one. The profile also determines what the reviewer is presented with: a discrete, predefined outcome that the AI selects by applying the decision model's rules and scoring logic.
Profiles come in two forms:
  • Direct decision - the AI picks one of your outcomes for each case. Each outcome carries its own rule set. The AI may select only one of the outcomes you define. If no outcome accommodates the rule evaluation, an Unknown outcome is presented to the reviewer.
  • Scored decision - conditions contribute points, and the total lands in a score band that names the outcome. Use a scored profile when the outcome depends on a range of calculated scores. Points are attached to specific criteria, which you set and see against those rules in the decision model.
For a direct decision profile, each outcome is labeled and assigned a polarity - Positive, Negative, or Neutral - which controls only how the outcome is styled, not how it is chosen. In the reviewer experience, Positive outcomes appear green, Neutral outcomes grey, and Negative outcomes red. For a scored decision profile, each outcome is a score band with a minimum and a maximum. Bands are matched in order from top to bottom and their bounds are inclusive.
Warning:
A decision profile is shared. Editing one updates it for every policy that uses it, and those policies may need regenerating before the change takes effect. Saving a profile also regenerates the decision model's rule tree from the AI, replacing any manual tree edits.
How rules are evaluated​
A decision model is a tree. Rule groups nest inside other rule groups and bottom out in conditions, each of which is a single check against a field extracted from the record.
Every rule group declares how its children are judged:
QualifierMeaning
All are requiredEvery item below must be met.
Any 1 is requiredAt least one item below must be met.
First matchItems are evaluated in order and evaluation stops at the first one met.
In a First match group, the order of the items decides which one is applied, so set that order deliberately. For guidance on picking a qualifier, structuring requirements, and keeping outcomes mutually exclusive, see Refining decision model rules.
Conditions are backed by a catalog of extracted fields. Each field has a data type and a description of how the AI locates it in the record, and records which scoring criteria use it. Avoid changing an extracted field to text that the policy document does not contain.
Policy versions and statuses​
Saving an edited decision model creates a new numbered version. Versions are sequential and permanent, and cases that have already been decided keep the version they ran against - regenerating a policy affects new cases only.
Each version carries a status, which is also aggregated on the Policies page:
StatusMeaning
ActiveThe version was generated successfully and is available for use.
PendingGeneration is still in progress.
FailedGeneration did not complete. The version cannot be used.
How a policy reaches a summary​
A policy becomes part of a summary through a template. In the template editor, a section set to the Policy output type is bound to one published policy. When a record is processed, the AI evaluates that policy's rules against the record and the section renders the outcome, the score for scored profiles, a confidence rating, a written rationale, and a breakdown of which rules were met.
Reviewers can then accept or reject the outcome independently of the overall review, which feeds the policy's own feedback loop.
