industry-department-solutions
Financial Services Solutions user guide
  • Overview
    • About financial services solutions
  • Financial Crime Compliance (FCC) solutions
  • Loan Origination Solution
Ce contenu n’est pas disponible dans la langue sélectionnée. La version en anglais est affichée à la place.
Review a loan application
Review an AI-generated loan risk assessment, verify agent findings against the underlying source data, and make a lending decision in the Loan Setup application.
Review a summarized view of agent and rule findings against the underlying LOS, core system, or document data. Applications become available for review after all agents and rules have completed processing.
Prerequisites​
  • You have access to the Loan Setup application.
  • You are a member of the Business User Group or have been assigned as an analyst for this loan application.
  • At least one loan application has a status of Ready to review in the loan table.
Open a loan application​
  1. Open the Loans page from the top navigation.
  2. Use the status filter to select Ready to review to narrow the list to applications needing review.
  3. Optionally use the analyst filter to display only applications assigned to you.
  4. Select the row for the loan application you want to review.
Result: The loan detail view opens, showing the Review status summary and the individual Review findings for the application.
Review agent findings​
The loan detail view displays two sections: Review status at the top, with a consolidated narrative of all findings, and Review findings below, with the configured categories of agentic checks and rules. For example, these categories can include Address Verification, Income calculation & validation, and Mortgage/Property Review. Your institution can add or remove categories.
  1. Review all applicable review cards in the Review status section and select any of the following cards:
    • All findings to navigate directly to the Review findings section and browse all items.
    • Needs attention to navigate to the first item that requires your attention.
    • Confirmed issues to navigate to any of the findings whose issues were confirmed.
  2. Review the Loan details panel on the left side of the detail view to confirm the structured loan data:
    • Loan amount
    • Credit score
    • Loan-to-value (LTV) ratio
    • Debt-to-income (DTI) ratio
    • Interest rate
    • Other key fields
  3. In the Review findings section, begin reviewing in detail every item on the list and select any of the following:
    • Clear if the finding raises no concern.
    • Issue if the finding identifies a problem that must be addressed.
    • Follow up to flag the item as requiring a follow-up from the borrower.
    • Add note to write a new note associated with the review finding.
    • Restart review if you want to restart the automated review of a specific item.
  4. Optionally, select Share feedback for an automated finding, then indicate whether It got it right or It needs correction.
  5. For a cleared review item, select Credit report to open the Credit report dialog and review details of the borrower's credit score from a different loan origination source.
  6. Select the More Actions icon and choose between the following:
    • Clear reviewer input: to clear all notes from a reviewer.
    • Restart review: to restart the overall automated review of a loan.
Result: Each reviewed finding is marked Clear or Issue, and any feedback, follow-ups, and notes you added are recorded against it.
Review supporting loan context​
Alongside the agent findings, use the supporting sections of the loan detail view to inform your decision.
  1. In Loan Comments Summary, review the Key notes (AI-summarized points drawn from the loan's loan origination system comments) for context that may affect your decision.
  2. In Property information, confirm the collateral details and automated valuation (AVM). Select View more property data for assessment and latest-transaction details.
  3. In Required documents, confirm each required document has been provided. Select a document's checkbox to mark it as received.
Result: You have reviewed the supporting loan context and marked the required documents as received, and you have the information needed to make a lending decision.
