industry-department-solutions
Financial Services Solutions user guide
  • Overview
    • About financial services solutions
  • Financial Crime Compliance (FCC) solutions
  • Loan Origination Solution
Ce contenu n’est pas disponible dans la langue sélectionnée. La version en anglais est affichée à la place.
About Loan Setup
Loan Setup capability of the Loan Origination Solution, which uses agentic AI to automate loan analysis and risk assessment, including how it is triggered, how Maestro orchestrates processing, and its key capabilities.
Loan Setup is a capability of the Loan Origination Solution that uses agentic AI to automate the analysis and risk assessment of loan applications. It is delivered as a UiPath App hosted on Automation Cloud.
Loan Setup reduces the time analysts spend manually reviewing loan documents, assessing borrower risk, and synthesizing data across multiple source systems. It uses specialized AI agents and flexible business rules that cover each distinct domain of loan review.
How it works​
Loan Setup is triggered via a Maestro API endpoint. When a loan requires processing, the customer's dispatcher RPA (or a LOS event trigger) calls the endpoint with the loan ID.
Maestro then invokes the customer's data extraction RPAs to pull structured data from the core banking system and LOS, and their data transformation RPAs to convert that data into the format the solution expects. Documents are retrieved separately through document metadata and retrieval RPAs.
Maestro runs AI agents and customizable business rules in sequence, with one category per agentic check or business-rule section. Results are stored in UiPath Data Fabric and surfaced in the loan analyst UI.
Note:
UiPath Data Fabric is available in preview. Preview features are subject to change based on customer feedback. For the general availability timeline, contact your UiPath representative.
After all agents and rules complete processing, the loan application becomes available for analyst review. An analyst reviews the AI-generated findings and rule checks, consults the underlying data sources, and triages issues to identify risks and inconsistencies.
Key capabilities​
CapabilityDescription
Agentic AI loan analysisSpecialized agents each analyze a distinct domain of loan review, returning structured findings per category
Deterministic rules engineEvaluates structured loan data against deterministic business rules extracted from your institution's policy documents, returning per-rule verdicts alongside the AI agent findings
Automated document ingestionIXP (Intelligent Xtraction Processing) classifies and extracts data from uploaded loan documents; Document Understanding may additionally be used for standardized document types to improve classification and extraction accuracy
Risk-flagged summariesAgent findings are organized by category with pass, warning, or risk badges per section
Human-in-the-loop reviewAnalysts review AI findings and rule checks, then submit Clear or Issue per finding. They can also mark findings for follow-up, add notes, and share feedback on automated findings
Streamlined communicationConfirmed issues are automatically populated in an email through Send Email, ready to share with internal or external recipients
Integration with core banking systemsConnects to your institution's core banking system, LOS, and document management system through the RPA Integration Contract framework. Your institution builds the RPA implementations tailored to your specific systems
Dashboard analyticsThe Dashboard surfaces key metrics for loan processing time and issues found in loan packets. The Loans page shows per-loan key performance indicator (KPI) cards for review deadlines
Application sections​
Loan Setup has two areas, accessible from the top navigation of the UI.
SectionPurpose
DashboardAn analytics overview of loan setup performance: average loan setup time against target, first-pass decision rate, service-level agreement (SLA) compliance, top issues, and loan volume over time.
LoansThe loan applications workspace for analyst review. KPI cards summarize review deadlines, and the applications table lists each loan with its review status and whether issues were found.
Solution delivery model​
Loan Setup is delivered as a closed-source solution. The core workflows, agents, and application components are developed, maintained, and updated by UiPath. Your institution does not receive editable source code for these components.
UiPath continuously iterates on Loan Setup as best practices for agentic automation evolve. Improvements to agent decomposition, prompt engineering, tools, and evaluations are distributed through updates to the closed-source components without requiring code changes within your systems. Updates are deployed into your Development and UAT environments first, with production deployment following your institution's established release schedule.
If an issue originates in the solution and is outside your institution-specific customizations, UiPath escalates the issue, fixes it, and deploys the correction to your environment. Your institution's extensibility point is the RPA Integration Contract framework, which provides a stable interface for connecting to your core banking, LOS, and document management systems.
User groups and permissions​
Loan Setup uses three user groups with distinct roles and permission scopes.
GroupRoleKey permissions
UiPath Developers, Professional Services, PartnersSystem administrators and implementation personnel who configure and deploy the solutionOrchestrator access; Data Fabric Designer, Data Writer, and Data Reader; IXP access
Business User GroupAnalysts and managers who perform loan application reviewData Fabric Data Writer and Data Reader; application access
Robot AccountsUnattended robot identities that run the processing pipelineData Fabric Data Writer and Data Reader; Orchestrator queue and job execution
These groups are created in UiPath Authentication within your cloud tenant. UiPath Developers, Professional Services, and Partners receive only the minimally required permissions needed for deployment and configuration work. As platform capabilities evolve and new functionality is added, access requirements may be updated.
Data Fabric permissions​
Data Fabric permissions are managed inside Data Fabric independently of UiPath Authentication.
GroupRequired Data Fabric access
Robot AccountsData Writer, Data Reader
UiPath Developer GroupDesigner, Data Writer, Data Reader
Business User GroupData Writer, Data Reader
Get started​
Request a demo to connect with the UiPath team about the Loan Origination Solution.
