industry-department-solutions
Financial Services Solutions release notes
  • Financial Crime Compliance solution release notes
    • 2026
      • March 2026
  • Loan origination solution release notes
      • August 2026
Ce contenu n’est pas disponible dans la langue sélectionnée. La version en anglais est affichée à la place.
August 2026
August 2026 release notes for the Loan Origination Solution in Automation Cloud.
August 12, 2026​
Loan Origination Solution is generally available (GA)​
The Loan Origination Solution is now generally available. Both capabilities, Loan Setup and Quality Control (QA/QC), have moved from Controlled GA to general availability.
For an overview of the solution and its architecture, see About Loan Origination Solution.
Note:
Both capabilities rely on UiPath Data Fabric, which is available in preview. Preview features are subject to change based on customer feedback. For the general availability timeline, contact your UiPath representative.
August 7, 2026​
Loan Origination Solution is in Controlled General Availability (CGA)​
The Loan Origination Solution is a UiPath industry solution for financial services that automates key stages of the origination lifecycle using agentic AI. The initial release includes two capabilities: Loan Setup, which automates loan analysis and risk assessment, and Quality Control (QA/QC), which automates document validation across pre-funding and post-closing stages. The solution is available in Controlled GA. For access, contact your UiPath representative.
Note:
Loan Setup​
  • Agentic AI loan analysis across six review domains: Loan Setup runs a configurable set of specialized AI agents (by default: Address Verification, Credit report & liability review, Income calculation & validation, Loan eligibility, Mortgage/Property Review, and Other), each returning a narrative summary and flagged risk items. Applications are marked Ready to review once agent processing completes. For details, see Loan detail reference.
  • API-triggered workflow via UiPath Maestro: The end-to-end loan analysis workflow is orchestrated by UiPath Maestro. Processing is initiated when the customer's dispatcher RPA calls the Maestro API endpoint with a loan ID. Maestro invokes the customer's data extraction and transformation RPAs, runs AI agents in sequence, and writes structured outputs to UiPath Data Fabric. For details, see Loan application workflow.
  • RPA Integration Contract framework: Loan Setup includes a standardized RPA Integration Contract framework that defines the input and output schemas for each system integration point in the processing pipeline. Organizations build RPA implementations against their core banking, LOS, and document management systems and register them in the FINSProcessRegistry Data Fabric table. Four contract types are supported: DocumentMetadata, DocumentRetrieval, DataRetrieval, and DataParse. For details, see RPA integration contracts.
Quality Control (QA/QC)​
  • Automated document classification and extraction: Quality Control uses IXP (Intelligent Xtraction Processing) to classify uploaded loan documents against the institution's expected document checklist, extract structured field values, and identify missing required documents. For details, see Quality control workflow.
  • Business rule evaluation across single and cross-document rules: The Quality Control agent evaluates each document against configurable business rules, returning No issue, Issue found, or Inconclusive per rule, with support for cross-document comparisons. Reviewers confirm or dismiss findings in a side-by-side document viewer and can view the agent's reasoning for each evaluation. For instructions, see Review a document.
  • AI-generated issues email: Reviewers can generate a pre-drafted email summarizing confirmed issues for the loan officer directly from the loan detail view. The email is AI-generated from the loan's review findings and is fully editable before sending. For instructions, see Generate an issues email.
  • Configurable audit report generation: Reviewers can generate a structured audit report for each loan, selecting which sections to include: agent findings, issue summary, activity timeline, and additional notes. For instructions, see Generate an audit report.
  • RPA Integration Contract framework: Quality Control includes a standardized RPA Integration Contract framework that defines the input and output schemas for each system integration point in the processing pipeline. Organizations build RPA implementations against their core banking, LOS, and document management systems and register them in the FINSProcessRegistry Data Fabric table. Four contract types are supported: DocumentMetadata, DocumentRetrieval, DataRetrieval, and DataParse. For details, see RPA integration contracts.
  • Simple and Preferred deployment modes: Simple mode allows manual document upload via the application interface, requiring no system integration. Preferred mode automates document retrieval using RPA Integration Contracts. For details on Simple mode, see Add a loan.
  • August 12, 2026​
  • Loan Origination Solution is generally available (GA)​
  • August 7, 2026​
  • Loan Origination Solution is in Controlled General Availability (CGA)​
