# Authorize using an External Application and retrieve the available resources
> Authorize an External Application and retrieve available Document Understanding resources, including project IDs and Swagger configuration.
1. Create a new Document Understanding<sup>TM</sup> project and retrieve the `projectId` (found within the project's URL).
   For this example we are using the predefined project<sup>*</sup> available in Swagger, identifiable with this `projectID`: **00000000-0000-0000-0000-000000000000.**
   :::note
   The predefined project is not visible in the Document Understanding UI. It provides programatic access to the available public ML models.
2. Create an External Application where Document Understanding is used as a **Resource** and it includes all the available **Application Scopes**.
3. Initiate a curl call to the Identity Service for obtaining a token.
curl --data \
-urlencode "scope=Du.Digitization"  --data \
-urlencode "client_id={app_id}" --data \
-urlencode "client_secret={app_secret}" --data \
-urlencode "grant_type=client_credentials" https://cloud.uipath.com/identity_/connect/token
:::note
The Authorization token has an expiration period. See the following response for the expiration and make sure to renew it before it expires.
"access_token": "eyJh**CRaKrg",
"expires_in": 3600,
"token_type": "Bearer",
"scope": "Du.Digitization.Api"
