# Intelligent Keyword Classifier
> The [Intelligent Keyword Classifier](document-classification-intelligent-keyword-classifier.md) is a classifier that uses the word vector it learns from files of certain document types to perform document classification.
## What Is Intelligent Keyword Classifier
The algorithm is built around the concept of repeating content for the same document type and starts from the premise that document types have a series of words that usually occur in those document types, thus allowing for a vector similarity computation.
When classifying a file into a document type, the **Intelligent Keyword Classifier**:
* finds the closest word vector a file is more similar to,
* reports on the highest scoring document type, with the underlying matching main words.
The **Intelligent Keyword Classifier** also has **file splitting** capabilities, meaning that it can report more than one class for a given file, for separate page ranges.
## When To Use
You should consider using this classifier if:
* your files contain one or more document types within a single file
* your document types are relatively easy to differentiate as far as content goes.
## How To Train
Place the [Intelligent Keyword Classifier Trainer](https://docs.uipath.com/activities/docs/intelligent-keyword-classifier-trainer) activity in a [Train Classifiers Scope](https://docs.uipath.com/activities/docs/train-classifiers-scope), and configure it accordingly.
We cannot enforce training file consistency across parallel trainings at the activity level. Two possible solutions for this issue are provided by [Document Understanding Process](du-document-understanding-process.md). Both consist of traffic control:
1. lock files (implemented by default in the process): rename the file using the `.lock` extension, modify and save the file, then rename the file again, removing the `.lock` extension
2. manual setup of a special queue: create an empty queue in Orchestrator and integrate your two activities from the project.
For more information on how to train a Classifier, check [this page](document-classification-intelligent-keyword-classifier.md) that describes the process of using the Manage Learning wizard.
## Learn More
Learn more about **Intelligent Keyword Classifier**, by following this [link](document-classification-intelligent-keyword-classifier.md).
