guide de référence uipathctl
Dernière mise à jour 28 févr. 2026
préreq uipathctl rke2
Commandes de vérification des prérequis.
uipathctl rke2 prereq [flags]
Options
      --excluded strings   components to be excluded from execution, defaults to none
  -h, --help               help for prereq
      --included strings   components to be included in the execution, defaults to all
  -o, --output output      output format. one of [json,yaml,text] (default text)
      --upgrade            include upgrade-related checks
Options héritées des commandes parent
  • Description
  • Options
  • Options héritées des commandes parent
