- Vue d'ensemble (Overview)
- Pré-installation
- Administration du cluster
- cluster uipathctl
- uipathctl cluster migration
- uipathctl config argocd
- uipathctl version
- Sauvegarde et restauration
- instantané uipathctl
- uipathctl snapshot delete
- uipathctl snapshot list
- uipathctl snapshot restore
- Gestion des certificats
- Mettre à niveau
- Authentification
- Surveillance et alerte
- Résolution des problèmes
uipathctl manifeste liste-applications
Guide de référence uipathctl
Dernière mise à jour 11 nov. 2024
Chargez le fichier de configuration trouvé dans le paramètre et répertorie les applications créées sur sa base. La configuration de Runtime est utilisée pour déterminer les applications requises. La sortie est toujours sous forme de tableau. Par défaut, la liste est triée par ordre alphabétique.
uipathctl manifest list-applications PATH [flags]
# List the applications which are installed based on the configuration found in input.json
uipathctl manifest list-applications input.json
# List the applications which are installed based on the configuration found in input.json.
# Sort them by the order in which they need to be installed based on dependencies between them.
uipathctl manifest list-applications input.json/cluster_config.json --sort-by topological
# List the applications without headers
uipathctl manifest list-applications input.json/cluster_config.json --no-headers
# Override the initial list of enabled components
uipathctl manifest list-applications input.json/cluster_config.json --override gatekeeper,redis
-h, --help help for list-applications
--is-required string to check whether the component needs to install
--no-headers if true, print the output without headers
--override strings optional list of components to override the components enabled in input.json/cluster_config.json file
--sort-by sortBy if set, sort the output by the given criteria. Valid values are: [alphabetical, topological] (default alphabetical)
