guide de référence uipathctl
Dernière mise à jour 24 févr. 2026
téléchargement de la configuration d’Orchestrator uipathctl
Télécharger des fichiers, des extensions Nlog ou des plug-ins de magasin sécurisés sur le stockage
uipathctl config orchestrator upload [flags]
Exemples
# Upload files to storage
uipathctl config orchestrator upload --storage-directory /path/to/storage/directory
# Upload nlog extensions to storage
uipathctl config orchestrator upload --nlog-extensions-directory /path/to/nlog/extensions/directory
# Upload secure store plugins to storage
uipathctl config orchestrator upload --securestore-plugins-directory /path/to/securestore/plugins/directory
# Upload files to external storage
uipathctl config orchestrator upload --storage-directory /path/to/storage/directory --is-external-storage
# Upload nlog extensions to external storage
uipathctl config orchestrator upload --nlog-extensions-directory /path/to/nlog/extensions/directory --is-external-storage
# Upload secure store plugins to external storage
uipathctl config orchestrator upload --securestore-plugins-directory /path/to/securestore/plugins/directory --is-external-storage
Options
  -h, --help                                   help for upload
    --is-external-storage                    flag whether the storage is external
    --namespace string                       The namespace where UiPath Automation Suite is deployed (default "uipath")
    --nlog-extensions-directory string       location of the nlog extensions on the local disk
    --securestore-plugins-directory string   location of the securestore plugins on the local disk
    --storage-directory string               location of the storage directory on the local disk
Options héritées des commandes parent
  • Description
  • Exemples
  • Options
  • Options héritées des commandes parent
