Last updated 20 sept. 2024
uipathctl snapshot delete
Supprimez la sauvegarde d'instantané.
uipathctl snapshot delete (name | --all) [flags]uipathctl snapshot delete (name | --all) [flags]
Options
-a, --all     Delete all the snapshots
  -f, --force   Forcibly delete the snapshot without confirmation
  -h, --help    help for delete  -a, --all     Delete all the snapshots
Options héritées des commandes parent
      --timeout duration    timeout of the command (default 1h0m0s)      --context string      name of the kubeconfig context to use
  • Description
  • Options
  • Options héritées des commandes parent
Forum de la communauté UiPath
Confiance et sécurité
© 2005-2024 UiPath Tous droits réservés.
