Last updated 20 sept. 2024
uipathctl prereq run
Exécute les vérifications des prérequis pour valider la réussite de l'installation.
uipathctl prereq run PATH [flags]uipathctl prereq run PATH [flags]
Exemples
# Runs all the prerequisite checks
        uipathctl prereq run input.json --versions versions.json
Options
-h, --help              help for run
--versions string   path to versions file  -h, --help              help for run
Options héritées des commandes parent
--excluded strings    components to be excluded from execution, defaults to none
--included strings    components to be included in the execution, defaults to all
--timeout duration    timeout of the command (default 1h0m0s)--context string      name of the kubeconfig context to use
  • Description
  • Exemples
  • Options
  • Options héritées des commandes parent
Forum de la communauté UiPath
Confiance et sécurité
© 2005-2024 UiPath Tous droits réservés.
