Last updated 20 sept. 2024
uipathctl prérequis
Exécute les vérifications des prérequis.
uipathctl prereq [flags]uipathctl prereq [flags]
Options
--excluded strings   components to be excluded from execution, defaults to none
  -h, --help               help for prereq
--included strings   components to be included in the execution, defaults to all--excluded strings   components to be excluded from execution, defaults to none
Options héritées des commandes parent
--timeout duration    timeout of the command (default 1h0m0s)--context string      name of the kubeconfig context to use
  • Description
  • Options
  • Options héritées des commandes parent
Forum de la communauté UiPath
Confiance et sécurité
© 2005-2024 UiPath Tous droits réservés.
