Last updated 20 sept. 2024
uipathctl manifeste liste-applications
Chargez le fichier de configuration trouvé dans le paramètre et répertorie les applications créées sur sa base. La configuration de Runtime est utilisée pour déterminer les applications requises. La sortie est toujours sous forme de tableau. Par défaut, la liste est triée par ordre alphabétique.
uipathctl manifest list-applications PATH [flags]uipathctl manifest list-applications PATH [flags]
Exemples
# List the applications which are installed based on the configuration found in input.json
        uipathctl manifest list-applications input.json
        # List the applications which are installed based on the configuration found in input.json.
        # Sort them by the order in which they need to be installed based on dependencies between them.
        uipathctl manifest list-applications input.json --sort-by topological
        # List the applications without headers
        uipathctl manifest list-applications input.json --no-headers
        # Override the initial list of enabled components
        uipathctl manifest list-applications input.json --override gatekeeper,redis
Options
-h, --help                 help for list-applications
--is-required string   to check whether the component needs to install
--no-headers           if true, print the output without headers
--override strings     optional list of components to override the components enabled in input.json file
--sort-by sortBy       if set, sort the output by the given criteria. Valid values are: [alphabetical, topological] (default alphabetical)  -h, --help                 help for list-applications
Options héritées des commandes parent
--timeout duration    timeout of the command (default 1h0m0s)--context string      name of the kubeconfig context to use
  • Description
  • Exemples
  • Options
  • Options héritées des commandes parent
Forum de la communauté UiPath
Confiance et sécurité
© 2005-2024 UiPath Tous droits réservés.
