Last updated 20 sept. 2024
uipathctl health diagnose
Diagnostiquez la dernière opération de synchronisation infructueuse à l'aide de l'API Kubernetes.
uipathctl health diagnose PATH [flags]uipathctl health diagnose PATH [flags]
Exemples
# Diagnose the last unsuccessful sync operation
		uipathctl health diagnose input.json
Options
-h, --help              help for diagnose
--versions string   path to versions file  -h, --help              help for diagnose
Options héritées des commandes parent
--excluded strings    components to be excluded from execution, defaults to none
--included strings    components to be included in the execution, defaults to all
  -o, --output output       output format. one of [json,yaml,text,junit] (default text)
--timeout duration    timeout of the command (default 1h0m0s)--context string      name of the kubeconfig context to use
  • Description
  • Exemples
  • Options
  • Options héritées des commandes parent
Forum de la communauté UiPath
Confiance et sécurité
© 2005-2024 UiPath Tous droits réservés.
