- Vue d'ensemble (Overview)
- Prérequis
- Vérifications des prérequis
- cluster uipathctl
- mise à niveau du cluster uipathctl
- Configuration uipathctl
- alertes de configuration uipathctl
- uipathctl - configuration des alertes - ajouter une adresse e-mail
- uipathctl santé
- bundle d'intégrité uipathctl
- vérification de l'état uipathctl
- uipathctl health diagnose
- uipathctl health test
- uipathctl identité
- uipathctl identity add-host-admin
- uipathctl identity enable-basic-auth
- manifeste uipathctl
- uipathctl manifest apply
- uipathctl manifest diff
- uipathctl manifest get
- uipathctl manifeste liste-applications
- uipathctl manifest render
- uipathctl prérequis
- uipathctl prereq create
- uipathctl prereq run
- Ressource uipathctl
- rapport de ressource uipathctl
- instantané uipathctl
- uipathctl snapshot delete
- uipathctl snapshot list
- uipathctl snapshot restore
- uipathctl sso
- uipathctl sso générer-connecteur
- uipathctl sso generate-overlays
- uipathctl sso generate-rbac
- uipathctl version
- Migration et mise à niveau
- Options de migration :
- Surveillance et alerte
- Administration du cluster
- Résolution des problèmes
Last updated 20 sept. 2024
Mettez à jour le destinataire des e-mails dans Alertmanager.
uipathctl config alerts update-email [flags]
# Update existing receiver in alertmanager, Pass only those parameters which needs to be update along with mandatory parameter name.
uipathctl config alerts update-email --name test --to "admin@example.com" --from "admin@example.com" --smtp "server.mycompany.com:443" --username admin --password "somepassword" --require-tls --ca-file "file path too rootCA" --cert-file "file path too server certificate" --key-file "file path too server key file"
--ca-file string File path containing the CA certificate of the SMTP server. This parameter is optional if the CA is private
--cert-file string File path containing the certificate of the SMTP server. This parameter is optional if the certificate is private
--from string The sender's email address
-h, --help help for update-email
--key-file string File path containing the private key of the certificate for the SMTP server. This parameter is required if the certificate is private
--name string Name of the email configuration
--password string SMTP authentication Password
--require-tls Boolean flag to denote that TLS is enabled at the SMTP server (default true)
--send-resolved Boolean flag to denote whether to send email on resolved alert (default true)
--smtp string SMTP server URL or IP, including port
--to string Receiver's email address
--username string SMTP authentication Username
