- Vue d'ensemble (Overview)
- Pré-installation
- uipathctl prérequis
- uipathctl prereq create
- uipathctl prereq run
- Administration du cluster
- cluster uipathctl
- uipathctl cluster migration
- uipathctl config argocd
- uipathctl version
- Sauvegarde et restauration
- instantané uipathctl
- uipathctl snapshot delete
- uipathctl snapshot list
- uipathctl snapshot restore
- Gestion des certificats
- Mettre à niveau
- Authentification
- Surveillance et alerte
- Résolution des problèmes
Guide de référence uipathctl
Last updated 11 nov. 2024
Exécute les vérifications des prérequis pour valider la réussite de l'installation.
uipathctl prereq run PATH [flags]
# Runs all the prerequisite checks
uipathctl prereq run input.json/cluster_config.json --versions versions.json
-h, --help help for run
--versions string path to versions file
--excluded strings components to be excluded from execution, defaults to none
--included strings components to be included in the execution, defaults to all
