guide de référence uipathctl
Dernière mise à jour 24 févr. 2025
bundle d'intégrité uipathctl
Générez un package d'assistance que vous pouvez utiliser pour résoudre les problèmes Automation Suite .
uipathctl health bundle [PATH] [flags]uipathctl health bundle [PATH] [flags]
Exemples
		# Generate the bundle in the OS temporary directory
		uipathctl health bundle input.json
		# Generate the bundle in a specific directory
		uipathctl health bundle input.json/cluster_config.json --output-dir /foo/bar
		# Generate the bundle without additional health/prereq report
		uipathctl health bundle input.json/cluster_config.json --skip-diagnose
Options
  -h, --help                help for bundle
  -p, --include-previous    If false, skips printing the logs for the previous instance of the container in a pod if it exists. (default true)
--limit-bytes int     Maximum bytes of logs to return. Defaults to no limit.
--output-dir string   path to output directory
--since-time string   Only return logs after a specific date (RFC3339). Defaults to all logs.
--skip-diagnose       skip additional health/prereq report
--versions string     path to versions file  -h, --help                help for bundle
Options héritées des commandes parent
--excluded strings    components to be excluded from execution, defaults to none
--included strings    components to be included in the execution, defaults to all
  -o, --output output       output format. one of [json,yaml,text,junit] (default text)
--timeout duration    timeout of the command (default 1h0m0s)--context string      name of the kubeconfig context to use
  • Description
  • Exemples
  • Options
  • Options héritées des commandes parent
Forum de la communauté UiPath
Confiance et sécurité
© 2005-2026 UiPath Tous droits réservés.
