Antivirus causes installation and operation issues
Solutions for antivirus-caused installation and operation issues in Automation Suite on Linux, including folder, process, and port exclusions.
Description​
Using an antivirus results in Automation Suite installation and operation issues.
Solution​
If you cannot exclude the Automation Suite nodes from antivirus scanning, take the following actions:
  • Add the following folders to the antivirus allowlist:
    /var/lib/rancher
    /var/lib/kubelet
    /opt/UiPathAutomationSuite
    /datadisk
    /var/lib/rancher/rke2/server/db
    /run/k3s
    /var/lib/rook
    /etc/rancher/rke2
    /tmp
    /run/containerd
    /var/run
    /var/lib/containerd
    /var/log/pods
    /var/log/containers
    /etc/cni
    /opt/cni
    /sys
    /proc
    /var/lib/rancher
    /var/lib/kubelet
    /datadisk
    /run/k3s
    /var/lib/rook
    /etc/rancher/rke2
    /tmp
    /run/containerd
    /var/run
    /var/lib/containerd
    /var/log/pods
    /var/log/containers
    /etc/cni
    /opt/cni
    /sys
    /proc
    Remarque :
    L’exclusion appliquée à ces dossiers doit être récursive.
  • Add the following processes and services to the antivirus allowlist:
    rke2-server          # For control-plane nodes
    rke2-agent           # For worker nodes
    containerd
    kubelet
    etcd
    kube-apiserver
    kube-controller-manager
    kube-scheduler
    containerd
    runc
    ctr
    containerd
    kubelet
    etcd
    kube-apiserver
    kube-scheduler
    containerd
    runc
    ctr
  • Add the following ports to the antivirus allowlist:
    6443        Kubernetes API server
    9345        RKE2 supervisor (node registration)
    2379-2380    etcd (control-plane nodes only)
    8472/udp    VXLAN overlay network
    10250       Kubelet API (metrics, logs, exec)
Assurez-vous que ces exclusions sont conservées après les redémarrages des nœuds.
If your antivirus application still causes issues, raise a support ticket with the antivirus provider.
  • Description​
  • Solution​
