# Adding a dedicated agent Node for Task Mining
> Before starting the Task Mining installation, make sure to check the [Hardware requirements](hardware-and-software-requirements.md). Task Mining has a dependency on AI Center; therefore, to use Task Mining, you must also install AI Center.
## Hardware requirements
After completing the Automation Suite installation, take the following steps to set up Task Mining.
## Enable Task Mining on the Cluster
If you already enabled Task Mining in the configuration during the main install, you can skip this step. If not, you need to enable AI Center and Task Mining by editing the configuration and rerunning the install.
### Editing the Configuration
You must enable `aicenter` and `task_mining` in the `cluster_config.json` configuration file when applying the advanced configuration.
#### `cluster_config.json`
Task Mining config
    "aicenter": {
        "enabled": Boolean
    "task_mining": {
        "enabled": Boolean
## Configuring a Dedicated Node for Task Mining
### Step One: Configure the Machine
Follow the steps for [configuring a server node](single-node-configuring-the-machines.md) to ensure the disk is partitioned correctly.
### Step Two: Copy the Interactive Installation Wizard to the Target Machine for Installation
#### For online installation
SSH to the right machine:
* If you added Task Mining to a single-node evaluation install, go to the machine and run this next step.
* If you added Task Mining to a multi-node HA-ready production install, go to any of the server nodes.
Run the following command to copy the contents of the `UiPathAutomationSuite` folder to the Task **Task Mining node** (username and DNS are specific to the **Task Mining node**):
sudo su -
scp -r /opt/UiPathAutomationSuite <username>@<node dns>:/opt/
scp -r ~/* <username>@<node dns>:/opt/UiPathAutomationSuite/
#### For offline installation
SSH to the primary installation node
Ensure that the `UiPathAutomationSuite` directory contains `sf-infra.tar.gz` file ( is a part of the [installation package download step](offline-multi-node-installation.md) )
scp -r ~/opt/UiPathAutomationSuite <username>@<node dns>:/var/tmp
### Step Three: Run the Interactive Install Wizard to Configure the Dedicated Node
SSH to the **Task Mining Node** and run the following commands:
sudo su -
cd /opt/UiPathAutomationSuite
yum install unzip jq -y
CONFIG_PATH=/opt/UiPathAutomationSuite/cluster_config.json
UNATTENDED_ACTION="accept_eula,download_bundle,extract_bundle,join_task_mining" ./installUiPathAS.sh
Connect via SSH to the Task Mining dedicated node & install the platform bundle on it using the script below.
sudo su
mv /var/tmp/UiPathAutomationSuite /opt
sudo chmod -R 755 /opt/UiPathAutomationSuite
sudo ./install-uipath.sh -i ./cluster_config.json -o ./output.json -k -j task-mining --offline-bundle ./sf-infra.tar.gz --offline-tmp-folder /opt/UiPathAutomationSuite/tmp --install-offline-prereqs --accept-license-agreement
### Step Four: Enabling Kubectl
Run below command to set the kubectl context on taskmining machine
sudo su -
export KUBECONFIG=/var/lib/rancher/rke2/agent/kubelet.kubeconfig
export PATH=$PATH:/var/lib/rancher/rke2/bin
kubectl get nodes
You should see the nodes and their corresponding names. You need the name of the **Task Mining node** for the next step.
### Step Five: Verifying Task Mining Configuration
Finally, run the following command to check if the **Task Mining node** is configured. Please update the **\&lt;node name\&gt;** with **Task Mining node** name in below command.
kubectl describe node <node name> | grep -i "taints"
Above command should return you the following output
![docs image](https://dev-assets.cms.uipath.com/assets/images/automation-suite/automation-suite-206447-8ddf365a.webp)
At this point, you have successfully completed the installation for Task Mining. Sign in to the Automation Suite Portal and enable it in the tenant management UX under the Admin section.
## Configuring email
You must configure system email notifications as Task Mining relies on the Automation Suite notification system to send emails.
## Starting a Task Mining project
For instructions on creating a Task Mining project, see the [Task Mining documentation](https://docs.uipath.com/task-mining/automation-suite/2022.10/user-guide/project-setup-as).
## Configuring the Task Mining ML Model in AI Center
Follow the steps for the given deployment type, online or offline.
### Online and Offline Installations
Before proceeding with the steps below, it is mandatory to start with following the steps from [Uploading ML Packages](https://docs.uipath.com/ai-fabric/docs/managing-ml-packages#uploading-ml-packages).
After uploading the ML package, follow the listed steps:
1. Access AI Center home page for your tenant and click on the **Create Project** button. This project can be named anything you want but we recommend matching it to the name of your Task Mining project.
2. From the project, navigate to the **ML Packages** page and then choose **Out of the box Packages**
   ![docs image](https://dev-assets.cms.uipath.com/assets/images/automation-suite/automation-suite-206851-e643aa8e.webp)
3. Select the UiPath Task Mining package.
   ![docs image](https://dev-assets.cms.uipath.com/assets/images/automation-suite/automation-suite-206303-cf18e531.webp)
4. Select **TMAnalyzerModel** and click **Submit**.
:::note
Please always select the latest version of the model packages.
5. Name the package, choose the most recent package version, and click **Submit** to create a machine-learning deployment package.
## Increasing secondary disk/Longhorn storage
As Task Mining is a data-heavy application, we recommend an additional 1024 GB of storage to handle the screenshots and metadata collected during studies. After adding a secondary disk, you must resize the Longhorn storage to incorporate it.
### Configuring a new disk in the cluster
You can add the additional disk either pre- or post installation. If you add it post-installation, you must take additional steps to configure the new disk in the cluster.
For details, see [Configuring new data disk in the cluster](multi-node-configuring-the-machines.md).
### Increasing storage capacity
To increase the storage capacity after completing the installation, navigate to `UiPathAutomationSuite` folder and run the following command:
sudo su -
sudo ./configureUiPathAS.sh objectstore resize-pvc --size 1000Gi --sub-component data
