guide de référence uipathctl
préreq uipathctl rke2
Sous-commandes de vérification des prérequis spécifiques à RKE2.
Description​
Commandes de vérification des prérequis.
uipathctl rke2 prereq [flags]
Options​
      --excluded strings   components to be excluded from execution, defaults to none
  -h, --help               help for prereq
      --included strings   components to be included in the execution, defaults to all
  -o, --output output      output format. one of [json,yaml,text] (default text)
      --upgrade            include upgrade-related checks
Options héritées des commandes parent​
  • Description​
  • Options​
  • Options héritées des commandes parent​
