guide de référence uipathctl
uipathctl registry seed
Référencez le registre Docker dans Automation Suite.
Description​
Registre docker de référence.
uipathctl registry seed [flags]
Options​
      --dest-password string     Destination registry password
      --dest-registry strings    List of destination registry
                             Note: All registry needs to have same username password
      --dest-username string     Destination registry username
  -h, --help                     help for seed
      --num-worker int           Number of workers to seed images in parallel (default 3)
      --source-password string   Source registry password
      --source-registry string   Source registry
      --source-username string   Source registry username
      --tag-file string          Path to file containing list of image/helm-chart tags
      --tar-file string          Path to the tar file containing images
Options héritées des commandes parent​
  • Description​
  • Options​
  • Options héritées des commandes parent​
