Liens de téléchargement d’artefacts de correctif
Liens pour télécharger les artefacts de correctif pour Automation Suite sur EKS/AKS.
Cette page fournit les liens de téléchargement des artefacts requis pour appliquer un correctif.
2.2510.4 patches​
This section provides the download links for the artifacts required for Automation Suite on EKS/AKS 2.2510.4 patches.
2.2510.4+patch1​
uipathctl​
To download uipathctl for Automation Suite 2.2510.4+patch1, run one of the following commands, depending on your OS:
  • Linux :
    wget -O ~/uipathctl-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2.2510.4-patch1/uipathctl-2.2510.4-patch1-linux-amd64.tar.gz
  • Windows
    wget -O ~/uipathctl-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2.2510.4-patch1/uipathctl-2.2510.4-patch1-windows-amd64.tar.gz
  • macOS:
    wget -O ~/uipathctl-darwin-amd64.tar.gz https://download.uipath.com/uipathctl/2.2510.4-patch1/uipathctl-2.2510.4-patch1-darwin-amd64.tar.gz
as-cmk.tar.gz​
To download as-cmk.tar.gz for Automation Suite 2.2510.4+patch1, run the following command:
wget -O ~/as-cmk.tar.gz https://download.uipath.com/automation-suite/2.2510.4+patch1/as-cmk-2.2510.4+patch1.tar.gz
as-images.txt​
To download as-images.txt for Automation Suite 2.2510.4+patch1, run the following command:
wget -O ~/as-images.txt https://download.uipath.com/automation-suite/2.2510.4+patch1/air-images.txt
as-helm-charts.txt​
To download as-helm-charts.txt for Automation Suite 2.2510.4+patch1, run the following command:
wget -O ~/as-helm-charts.txt https://download.uipath.com/automation-suite/2.2510.4+patch1/embedded-helm-charts.txt
mirror-registry.sh​
To download mirror-registry.sh for Automation Suite 2.2510.4+patch1, run the following command:
wget -O ~/mirror-registry.sh https://download.uipath.com/automation-suite/2.2510.4+patch1/mirror-registry.sh
hydrate-registry.sh​
To download hydrate-registry.sh for Automation Suite 2.2510.4+patch1, run the following command:
wget -O ~/hydrate-registry.sh https://download.uipath.com/automation-suite/2.2510.4+patch1/hydrate-registry.sh
versions.json​
To download versions.json for Automation Suite 2.2510.4+patch1, run the following command:
wget -O ~/versions.json https://download.uipath.com/automation-suite/2.2510.4+patch1/versions.json
2.2510.2 Correctifs​
Cette section fournit les liens de téléchargement des artefacts requis pour Automation Suite sur EKS/AKS 2.2510.2 correctifs.
2.2510.2+patch2​
uipathctl​
Pour télécharger uipathctl pour Automation Suite 2.2510.2+patch2, exécutez l’une des commandes suivantes, selon votre système d’exploitation:
  • Linux :
    wget -O ~/uipathctl-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2.2510.2-patch2/uipathctl-2.2510.2-patch2-linux-amd64.tar.gz
  • Windows
    wget -O ~/uipathctl-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2.2510.2-patch2/uipathctl-2.2510.2-patch2-windows-amd64.tar.gz
  • MacOS:
    wget -O ~/uipathctl-darwin-amd64.tar.gz https://download.uipath.com/uipathctl/2.2510.2-patch2/uipathctl-2.2510.2-patch2-darwin-amd64.tar.gz
as-cmk.tar.gz​
Pour télécharger as-cmk.tar.gz pour Automation Suite 2.2510.2+patch2, exécutez la commande suivante:
wget -O ~/as-cmk.tar.gz https://download.uipath.com/automation-suite/2.2510.2+patch2/as-cmk-2.2510.2+patch2.tar.gz
as-images.txt​
Pour télécharger as-images.txt pour Automation Suite 2.2510.2+patch2, exécutez la commande suivante:
wget -O ~/as-images.txt https://download.uipath.com/automation-suite/2.2510.2+patch2/air-images.txt
as-helm-charts.txt​
Pour télécharger as-helm-charts.txt pour Automation Suite 2.2510.2+patch2, exécutez la commande suivante:
wget -O ~/as-helm-charts.txt https://download.uipath.com/automation-suite/2.2510.2+patch2/embedded-helm-charts.txt
mirror-registry.sh​
Pour télécharger mirror-registry.sh pour Automation Suite 2.2510.2+patch2, exécutez la commande suivante:
wget -O ~/mirror-registry.sh https://download.uipath.com/automation-suite/2.2510.2+patch2/mirror-registry.sh
Pour télécharger hydrate-registry.sh pour Automation Suite 2.2510.2+patch2, exécutez la commande suivante:
wget -O ~/hydrate-registry.sh https://download.uipath.com/automation-suite/2.2510.2+patch2/hydrate-registry.sh
versions.json​
Pour télécharger versions.json pour Automation Suite 2.2510.2+patch2, exécutez la commande suivante:
wget -O ~/versions.json https://download.uipath.com/automation-suite/2.2510.2+patch2/versions.json
2.2510.2+patch1​
uipathctl​
Pour télécharger uipathctl pour Automation Suite 2.2510.2+patch1, exécutez l’une des commandes suivantes, selon votre système d’exploitation:
  • Linux :
    wget -O ~/uipathctl-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2.2510.2-patch1/uipathctl-2.2510.2-patch1-linux-amd64.tar.gz
  • Windows
    wget -O ~/uipathctl-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2.2510.2-patch1/uipathctl-2.2510.2-patch1-windows-amd64.tar.gz
  • MacOS:
    wget -O ~/uipathctl-darwin-amd64.tar.gz https://download.uipath.com/uipathctl/2.2510.2-patch1/uipathctl-2.2510.2-patch1-darwin-amd64.tar.gz
as-cmk.tar.gz​
Pour télécharger as-cmk.tar.gz pour Automation Suite 2.2510.2+patch1, exécutez la commande suivante:
wget -O ~/as-cmk.tar.gz https://download.uipath.com/automation-suite/2.2510.2+patch1/as-cmk-2.2510.2+patch1.tar.gz
as-images.txt​
Pour télécharger as-images.txt pour Automation Suite 2.2510.2+patch1, exécutez la commande suivante:
wget -O ~/as-images.txt https://download.uipath.com/automation-suite/2.2510.2+patch1/air-images.txt
as-helm-charts.txt​
Pour télécharger as-helm-charts.txt pour Automation Suite 2.2510.2+patch1, exécutez la commande suivante:
wget -O ~/as-helm-charts.txt https://download.uipath.com/automation-suite/2.2510.2+patch1/embedded-helm-charts.txt
mirror-registry.sh​
Pour télécharger mirror-registry.sh pour Automation Suite 2.2510.2+patch1, exécutez la commande suivante:
wget -O ~/mirror-registry.sh https://download.uipath.com/automation-suite/2.2510.2+patch1/mirror-registry.sh
Pour télécharger hydrate-registry.sh pour Automation Suite 2.2510.2+patch1, exécutez la commande suivante:
wget -O ~/hydrate-registry.sh https://download.uipath.com/automation-suite/2.2510.2+patch1/hydrate-registry.sh
versions.json​
Pour télécharger versions.json pour Automation Suite 2.2510.2+patch1, exécutez la commande suivante:
wget -O ~/versions.json https://download.uipath.com/automation-suite/2.2510.2+patch1/versions.json
Correctifs 2.2510.1​
Cette section fournit les liens de téléchargement des artefacts requis pour Automation Suite sur les correctifs EKS/AKS 2.2510.1.
2.2510.1+patch1​
uipathctl​
Pour télécharger uipathctl pour Automation Suite 2.2510.1+patch1, exécutez l’une des commandes suivantes, selon votre système d’exploitation :
  • Linux :
    wget -O ~/uipathctl-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2.2510.1-patch1/uipathctl-2.2510.1-patch1-linux-amd64.tar.gz
  • Windows
    wget -O ~/uipathctl-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2.2510.1-patch1/uipathctl-2.2510.1-patch1-windows-amd64.tar.gz
  • MacOS:
    wget -O ~/uipathctl-darwin-amd64.tar.gz https://download.uipath.com/uipathctl/2.2510.1-patch1/uipathctl-2.2510.1-patch1-darwin-amd64.tar.gz
as-cmk.tar.gz​
Pour télécharger as-cmk.tar.gz pour Automation Suite 2.2510.1+patch1, exécutez la commande suivante :
wget -O ~/as-cmk.tar.gz https://download.uipath.com/automation-suite/2.2510.1+patch1/as-cmk-2.2510.1+patch1.tar.gz
as-images.txt​
Pour télécharger as-images.txt pour Automation Suite 2.2510.1+patch1, exécutez la commande suivante :
wget -O ~/as-images.txt https://download.uipath.com/automation-suite/2.2510.1+patch1/air-images.txt
as-helm-charts.txt​
Pour télécharger as-helm-charts.txt pour Automation Suite 2.2510.1+patch1, exécutez la commande suivante :
wget -O ~/as-helm-charts.txt https://download.uipath.com/automation-suite/2.2510.1+patch1/embedded-helm-charts.txt
mirror-registry.sh​
Pour télécharger mirror-registry.sh pour Automation Suite 2.2510.1+patch1, exécutez la commande suivante :
wget -O ~/mirror-registry.sh https://download.uipath.com/automation-suite/2.2510.1+patch1/mirror-registry.sh
Pour télécharger hydrate-registry.sh pour Automation Suite 2.2510.1+patch1, exécutez la commande suivante :
wget -O ~/hydrate-registry.sh https://download.uipath.com/automation-suite/2.2510.1+patch1/hydrate-registry.sh
versions.json​
Pour télécharger versions.json pour Automation Suite 2.2510.1+patch1, exécutez la commande suivante :
wget -O ~/versions.json https://download.uipath.com/automation-suite/2.2510.1+patch1/versions.json
2.2510.0 Dernière version Correctifs​
Cette section fournit les liens de téléchargement des artefacts requis pour Automation Suite sur EKS/AKS 2.2510.0 Correctifs.
2.2510.0+patch1​
uipathctl​
Pour télécharger uipathctl pour Automation Suite 2.2510+patch1, exécutez l’une des commandes suivantes, selon votre système d’exploitation :
  • Linux :
    wget -O ~/uipathctl-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2.2510.0-patch1/uipathctl-2.2510.0-patch1-linux-amd64.tar.gz
  • Windows
    wget -O ~/uipathctl-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2.2510.0-patch1/uipathctl-2.2510.0-patch1-windows-amd64.tar.gz
  • MacOS:
    wget -O ~/uipathctl-darwin-amd64.tar.gz https://download.uipath.com/uipathctl/2.2510.0-patch1/uipathctl-2.2510.0-patch1-darwin-amd64.tar.gz
as-cmk.tar.gz​
Pour télécharger as-cmk.tar.gz pour Automation Suite 2.2510+patch1, exécutez la commande suivante :
wget -O ~/as-cmk.tar.gz https://download.uipath.com/automation-suite/2.2510.0+patch1/as-cmk-2.2510.0+patch1.tar.gz
as-images.txt​
Pour télécharger as-images.txt pour Automation Suite 2.2510+patch1, exécutez la commande suivante :
wget -O ~/as-images.txt https://download.uipath.com/automation-suite/2.2510.0+patch1/air-images.txt
as-helm-charts.txt​
Pour télécharger as-helm-charts.txt pour Automation Suite 2.2510+patch1, exécutez la commande suivante :
wget -O ~/as-helm-charts.txt https://download.uipath.com/automation-suite/2.2510.0+patch1/embedded-helm-charts.txt
mirror-registry.sh​
Pour télécharger mirror-registry.sh pour Automation Suite 2.2510+patch1, exécutez la commande suivante :
wget -O ~/mirror-registry.sh https://download.uipath.com/automation-suite/2.2510.0+patch1/mirror-registry.sh
Pour télécharger hydrate-registry.sh pour Automation Suite 2.2510+patch1, exécutez la commande suivante :
wget -O ~/hydrate-registry.sh https://download.uipath.com/automation-suite/2.2510.0+patch1/hydrate-registry.sh
versions.json​
Pour télécharger versions.json pour Automation Suite 2.2510+patch1, exécutez la commande suivante :
wget -O ~/versions.json https://download.uipath.com/automation-suite/2.2510.0+patch1/versions.json
