# Generate a new secret
> Generate a new client secret for an external OAuth client in an Automation Suite organization using the Identity API, including required scope and response schema.
Generate a new client secret for the given external client.
## API endpoint
`GET https://{yourDomain}/{organizationName}/identity_/api/ExternalClient/{partitionGlobalId}/{clientId}`
## Scopes
Requires either one of the following scopes:
* `PM.OAuthApp`
* `PM.OAuthApp.Write`
* `PM.OAuthSecret.Write`
## Request headers
:::note
To obtain the `{access_token}`, make sure to authenticate through one of the methods described in [Authentication methods](https://docs.uipath.com/automation-suite/automation-suite/2.2510/api-guide/authentication-methods#authentication-methods).
## Request body
The request body contains the organization ID where the external client is located, and the corresponding client ID.
  "partitionGlobalId": "<organizationId>",
  "clientId": "<clientId>"
## Responses
### 200 Success
The client secret has been successfully created for the given external client.
"string"
