# Update Settings
> PUT endpoint for updating or creating organization and user settings, available to host and organization administrators with the PM.Setting scope.
As a host or organization administrator, use this endpoint to update existing settings or create new settings for a the specified organization and/or user ID.
## API Endpoint
`PUT` `/identity_/api/Setting`
## Scopes
Requires the following scopes:
* PM.Setting
* PM.Setting.Write
## Request Headers
:::note
To obtain the `{access_token}`, make sure to authenticate through one of the methods described [here](https://docs.uipath.com/automation-cloud/automation-cloud/latest/api-guide/authentication-methods#authentication-methods).
## Request Body
The request body contains the organization ID and the setting keys you want to update.
  "settings": [
      "key": "string",
      "value": "string"
  "partitionGlobalId": "string",
  "userId": "string"
## Responses
### 200 OK
The settings are updated with the information you provided.
## Example Request
Let's say you gathered all the information needed to build the API call.
* Your `{baseURL}` is: `https://cloud.uipath.com/{organizationName}/{tenantName}/`
* Your `{access_token}` is: `1234` (for length considerations).
* The `{partitionGlobalId}` is: `3fa85f64-5717-4562-b3fc-2c963f66afa6`
* You want to update the authentication settings, so you log in as a host admin.
The call should resemble the following example (cURL):
curl --location --request PUT 'https://cloud.uipath.com/{organizationName}/{tenantName}/identity_/api/Setting' \)\)
--header 'Authorization: Bearer 1234' \)\)
--data-raw '
    "settings": [
            "key": "Auth.Password.DefaultExpirationDays",
            "value": "0"
            "key": "Auth.Password.PasswordComplexity",
             "value": "{\"hasSpecialCharacter\":false,\"hasLowercase\":true,\"hasUppercase\":false,\"hasDigit\":true,\"Length\":\"10\"}"
            "key": "Auth.Password.PreviousUseLimit",
            "value": "1"
            "key": "Auth.Password.ShouldChangePasswordAfterFirstLogin",
            "value": "true"
            "key": "Auth.UserLockOut.DefaultAccountLockoutSeconds",
            "value": "0"
            "key": "Auth.UserLockOut.IsEnabled",
            "value": "false"
            "key": "Auth.UserLockOut.MaxFailedAccessAttemptsBeforeLockout",
            "value": "2"
    "partitionGlobalId": "3fa85f64-5717-4562-b3fc-2c963f66afa6"
Here is the response for a successful call:
        "id": 4,
        "value": "0",
        "partitionGlobalId": "3fa85f64-5717-4562-b3fc-2c963f66afa6",
        "userId": null
        "id": 1,
        "value": "{\"HasDigit\":true,\"HasLowercase\":true,\"HasSpecialCharacter\":false,\"HasUppercase\":false,\"Length\":10,\"RegexComplexity\":{\"HasDigitRegex\":\"(?=.*\\\\d)\",\"HasLowercaseRegex\":\"(?=.*[a-z])\",\"HasSpecialCharacterRegex\":\"(?=.*[^a-zA-Z\\\\d])\",\"HasUppercaseRegex\":\"(?=.*[A-Z])\",\"LengthRegex\":\"{10,}\",\"Regex\":\"(?=.*\\\\d)(?=.*[a-z]).{10,}\"}}",
        "userId": null
        "id": 3,
        "value": "1",
        "userId": null
        "id": 2,
        "value": "true",
        "userId": null
        "id": 26,
        "value": "0",
        "userId": null
        "id": 27,
        "value": "false",
        "userId": null
        "id": 28,
        "value": "2",
        "userId": null
