# Delete Users
> DELETE endpoint for removing multiple users from an organization by their user IDs.
Deletes multiple users from an organization, based on the users IDs.
## API Endpoint
`DELETE` `{accessURL}/{organizationName}/identity_/api/User`
Replace `{accessURL}` in all endpoint paths with the base URL for your cloud platform:
| Cloud platform | Access URL |
| Automation Cloud | `https://cloud.uipath.com/` |
| Automation Cloud Public Sector | `https://govcloud.uipath.us/` |
| Automation Cloud Dedicated | `https://{customURL}.dedicated.uipath.com/` |
## Scopes
Requires the following scopes:
* PM.User
* PM.User.Write
## Request Headers
:::note
To obtain the `{access_token}`, make sure to authenticate through one of the methods described [here](https://docs.uipath.com/automation-cloud/automation-cloud/latest/api-guide/authentication-methods#authentication-methods).
## Path Parameters
| Path param | Data type | Description |
| `partitionGlobalId`  (required) | String | The ID of the organization you want to retrieve the robot accounts for. |
## Request Body
The request body contains the list of user IDs you want to bulk delete from the organization.
  "partitionGlobalId": "string",
  "userIds": [
    "string"
## Responses
### 204 Success
The indicated robot accounts are deleted from the organization.
## Example Request
Let's say you gathered all the information needed to build the API call.
* Your `{baseURL}` is: https://cloud.uipath.com/{organizationName}/identity_
* Your `{access_token}` is: `1234` (for length considerations).
* The `{partitionGlobalId}` is: `3fa85f64-5717-4562-b3fc-2c963f66afa6`
* The users you want to delete have the following IDs:
  + Dolores Umbridge: `dol-2908`
  + Quirinus Quirrell: `qui-2609`
The call should resemble the following example (cURL):
curl --location --request DELETE 'https://cloud.uipath.com/{organizationName}/identity_/api/User' \
--data-raw '{
    "partitionGlobalId": "3fa85f64-5717-4562-b3fc-2c963f66afa6",
    "userIds": [
        "dol-2908", "qui-2609"
