# Get Org License Summary
> GET endpoint for retrieving the organization-level license summary, covering totals, allocations, and usage for robots, user licenses, and consumables.
Retrieves the license summary for your organization, including licensed and allocated robots, licensed and used user licenses, and licensed, allocated, and used consumables. Requires an external application with the scope `PM.License.Read`.
Find out how to [create an external application](https://docs.uipath.com/automation-cloud/automation-cloud/latest/admin-guide/authorizing-external-applications).
## API Endpoint
`GET` `{accessURL}/{organizationName}/license_/api/account/{accountId}/license-summary`
Replace `{accessURL}` in all endpoint paths with the base URL for your cloud platform:
| Cloud platform | Access URL |
| Automation Cloud | `https://cloud.uipath.com/` |
| Automation Cloud Public Sector | `https://govcloud.uipath.us/` |
| Automation Cloud Dedicated | `https://{customURL}.dedicated.uipath.com/` |
## Request Headers
--header 'Authorization: Bearer {access_token}'
:::note
To obtain the `{access_token}`, make sure to authenticate through the Resource Owner Password Credentials (ROPC) method described on the [Authentication Methods page](https://docs.uipath.com/automation-cloud/automation-cloud/latest/api-guide/authentication-methods#authentication-methods).
## Path Parameters
| Path param | Data type | Description |
| `accountId`  (required) | Guid | The ID of the organization for which to retrieve the license summary. |
## Responses
### 200 OK
Returns the license summary for the organization, split into three arrays:
* `robots` — for each robot type, the total licensed quantity (`total`) and the total allocated quantity (`allocated`). See [Robots](https://docs.uipath.com/automation-cloud/automation-cloud/latest/api-guide/license-codes#robots) for the available codes.
* `userLicenses` — for each user license, the total licensed quantity (`total`) and the total used quantity (`used`). See [User Licenses](https://docs.uipath.com/automation-cloud/automation-cloud/latest/api-guide/license-codes#user-licenses) for the available codes.
* `consumables` — for each consumable unit, the total licensed quantity (`total`), the total allocated amount (`allocated`), the total used amount (`used`), and the validity period (`startDate`, `endDate`) as Unix timestamps in seconds. See [Consumables](https://docs.uipath.com/automation-cloud/automation-cloud/latest/api-guide/license-codes#consumables) for the available codes.
### 404
No account license is allocated for the indicated organization.
## Example Request
The request should resemble the following example (cURL):
curl --location --request GET 'https://cloud.uipath.com/{organizationName}/license_/api/account/1234/license-summary' \
Here's the response body for a successful license summary retrieval:
```json
    "robots": [
            "code": "APPTESTR",
            "total": 5,
            "allocated": 2
            "code": "NONPR",
            "total": 0,
            "allocated": 0
            "code": "TAUNATT",
            "total": 5,
            "allocated": 2
            "code": "UNATT",
            "total": 5,
            "allocated": 2
            "code": "UNATT-HOSTING",
            "total": 0,
            "allocated": 0
    "userLicenses": [
            "code": "PMBU",
            "total": 5,
            "used": 0
            "code": "PMD",
            "total": 10,
            "used": 3
            "code": "IDU",
            "total": 55,
            "used": 1
            "code": "TSTNU",
            "total": 5,
            "used": 2
            "code": "AXPNU",
            "total": 100,
            "used": 10
            "code": "ACNU",
            "total": 2,
            "used": 0
            "code": "RPADEVPROCU",
            "total": 15,
            "used": 0
            "code": "RPADEVPRONU",
            "total": 15000,
            "used": 10
            "code": "CBNU",
            "total": 5,
            "used": 0
            "code": "ATTUNU",
            "total": 5,
            "used": 1
            "code": "PRONU",
            "total": 200,
            "used": 12
            "code": "CTZDEVNU",
            "total": 5,
            "used": 0
            "code": "BASICNU",
            "total": 10,
            "used": 7
            "code": "AKIT",
            "total": 100,
            "used": 0
            "code": "PLUSNU",
            "total": 2,
            "used": 5
    "consumables": [
            "code": "AGU",
            "total": 995658,
            "allocated": 130,
            "used": 1,
            "startDate": 1707177600,
            "endDate": 2230847999
            "code": "APPU",
            "total": 0,
            "allocated": 0,
            "used": 0,
            "startDate": null,
            "endDate": null
            "code": "FCCU",
            "total": 0,
            "allocated": 0,
            "used": 0,
            "startDate": null,
            "endDate": null
            "code": "HEAL",
            "total": 303330,
            "allocated": 1500,
            "used": 0,
            "startDate": 1762128000,
            "endDate": 1920844799
            "code": "HEALTEST",
            "total": 0,
            "allocated": 0,
            "used": 0,
            "startDate": null,
            "endDate": null
            "code": "LU",
            "total": 0,
            "allocated": 0,
            "used": 0,
            "startDate": null,
            "endDate": null
            "code": "MRSU",
            "total": 0,
            "allocated": 0,
            "used": 0,
            "startDate": null,
            "endDate": null
            "code": "PLTU",
            "total": 0,
            "allocated": 0,
            "used": 0,
            "startDate": null,
            "endDate": null
            "code": "RU",
            "total": 0,
            "allocated": 0,
            "used": 0,
            "startDate": null,
            "endDate": null
            "code": "SPR",
            "total": 0,
            "allocated": 0,
            "used": 0,
            "startDate": null,
            "endDate": null
            "code": "TEU",
            "total": 0,
            "allocated": 0,
            "used": 0,
            "startDate": null,
            "endDate": null
