# Deploying the package
> This page describes how to deploy an out-of-the-box Computer Vision ML package.
## Creating the ML package
To create a Computer Vision ML package, select the **AI Center** service from the left navigation bar, create a new project or access an existing one, and then select **ML Packages**.
### For offline installation
1. Select **Upload zip file**.
2. Under **Package name**, enter a package name.
3. Under **Upload package**, upload the Computer Vision ML package as a `.zip` file.
   To do so, you need to download the `cv-ondemand.tar.gz` bundle. For further details, go [here](https://docs.uipath.com/automation-suite/automation-suite/2023.4/installation-guide/downloading-installation-packages#cv-ondemandtargz).
4. Under **Input type**, select **Json** from the drop-down menu.
5. Under **Language**, select the corresponding Python language from the drop-down menu.
6. Enable the **Recommend GPU** toggle button.
7. Select **Create**.
### For online installation
1. Select **Out of the box Packages**.
2. Select **UiPath Computer Vision**.
3. Select **ComputerVision**.
4. Under **Choose Package Version**, select a package version from the drop-down menu.
5. Select **Submit**.
## Creating the ML skill
In the same project that you created the ML package, you need to:
1. Go to **ML Skills**.
2. Select **Create new**.
3. Under **Name**, enter a name for the ML skill.
4. Under **Choose Package**, select the ML package you just created from the drop-down menu.
5. Under **Choose package major version**, select a major version from the drop-down menu.
6. Under **Choose package minor version**, select a minor version from the drop-down menu.
7. Enable the **Enable GPU** toggle button.
8. Enable the **Make ML Skill Public** toggle button.
9. Select **Create**.
10. Once the ML skill is available, this can take up to 30 minutes, select the ML skill and copy the **Url**.
## Changing the endpoints on activity level
On activity level in your UiPath Studio project, you need to change:
* the **URL** property value of the CV Screen Scope activity, and
* the **Endpoint** property value of the UiPath Screen OCR activity
to the URL of the ML skill.
## Changing the endpoints on project level
The default URLs can also be changed from the [Project Settings](https://docs.uipath.com/studio/standalone/2023.4/user-guide/about-automation-projects#adjusting-project-settings) page.
### Changing the endpoint for CV Screen Scope
To change the endpoint for CV Screen Scope, go to **UiPath Studio** &gt; your project &gt; **Project Settings** &gt; **Computer Vision** &gt; **CV Screen Scope** &gt; **Server** &gt; **Run value/Debug value** &gt; change `https://cv.uipath.com` to the URL of the ML skill.
![docs image](https://dev-assets.cms.uipath.com/assets/images/ai-computer-vision/ai-computer-vision-375713-215ab9e4.webp)
When **Local Server** is set to **True**, the ML skill is over-written.
### Changing the endpoint for UiPath Screen OCR
To change the endpoint for UiPath Screen OCR, go to **UiPath Studio** &gt; your project &gt; **Project Settings** &gt; **OCR** &gt; **UiPath Screen OCR** &gt; **Endpoint** &gt; **Run value/Debug value** &gt; change `https://ocr.uipath.com` to the URL of the ML skill.
![docs image](https://dev-assets.cms.uipath.com/assets/images/ai-computer-vision/ai-computer-vision-375717-d57fc5fd.webp)
