# Light Text Classification
> *Out of the Box Packages &gt; UiPath Language Analysis &gt; LightTextClassification*
This is a generic, retrainable model for text classification. It supports all languages based on Latin characters, such as English, French, Spanish, and others. This ML Package must be trained, and if deployed without training first the deployment will fail with an error stating that the model is not trained. This model operates on Bag of Words. This model provides explainability based on n-grams.
## Model details
### Input type
JSON and CSV
### Input description
Text to be classified as String: 'I loved this movie.'
### Output description
JSON with class and confidence (between 0-1).
    "class": "7",
    "confidence": 0.1259827300369445,
    "ngrams": [
            "like",
            1.3752658445706787
            "like this",
            0.032029048484416685
### Recommend GPU
GPU is not required.
### Training enabled
By default, training is enabled.
## Pipelines
This package supports all three types of pipelines (Full Training, Training, and Evaluation). The model uses advanced techniques to find a performant model using hyperparameter search. By default, hyperparameter search (the **BOW.hyperparameter_search.enable** variable) is enabled. The parameters of the most performant model are available in the Evaluation Report.
### Dataset format
Three options are available to structure your dataset for this model : JSON, CSV and **AI Center** JSON format. The model will read all CSV and JSON files in the specified directory. For every format, the model expects two columns or two properties, **dataset.input_column_name** and **dataset.target_column_name** by default. The names of these two columns and/or directories are configurable using environment variables.
#### CSV file format
Each CSV file can have any number of columns, but only two will be used by the model. Those columns are specified by the **dataset.input_column_name** and **dataset.target_column_name** parameters.
Check the following sample and environment variables for a **CSV file format** example.
text, label
I like this movie, 7
I hated the acting, 9
The environment variables for the previous example would be as follows :
* **dataset.input_format**: `auto`
* **dataset.input_column_name**: `text`
* **dataset.target_column_name**: `label`
#### JSON file format
Multiple datapoints could be a part of the same JSON file.
Check the following sample and environment variables for a **JSON file format** example.
    "text": "I like this movie",
    "label": "7"
    "text": "I hated the acting",
    "label": "9"
#### ai_center file format
This is the deafult value of the environment variables which can be set, and this model will read all files in a provided directory with a `.json` extension.
Check the following sample and environment variables for an **ai_center file format** example.
    "annotations": {
        "intent": {
            "to_name": "text",
            "choices": [
                "TransactionIssue",
                "LoanIssue"
        "sentiment": {
            "to_name": "text",
            "choices": [
                "Very Positive"
        "ner": {
            "to_name": "text",
            "labels": [
                    "start_index": 37,
                    "end_index": 47,
                    "entity": "Stakeholder",
                    "value": " Citi Bank"
                    "start_index": 51,
                    "end_index": 61,
                    "entity": "Date",
                    "value": "07/19/2018"
                    "start_index": 114,
                    "end_index": 118,
                    "entity": "Amount",
                    "value": "$500"
                    "start_index": 288,
                    "end_index": 293,
                    "value": " Citi"
    "data": {
        "cc": "",
        "to": "xyz@abc.com",
        "date": "1/29/2020 12:39:01 PM",
        "from": "abc@xyz.com",
        "text": "I opened my new checking account with Citi Bank in 07/19/2018 and met the requirements for the promotion offer of $500 . It has been more than 6 months and I have not received any bonus. I called the customer service several times in the past few months but no any response. I request the Citi honor its promotion offer as advertised."
For leveraging the previous sample JSON, the environment variables need to be set as follows:
* **dataset.input_format**: `ai_center`
* **dataset.input_column_name**: `data.text`
* **dataset.target_column_name**: `annotations.intent.choices`
### Training on GPU or CPU
GPU is not required for training
### Environment variables
  * The name of the input column containing the text.
  * Default value is `data.text`.
  * Make sure that this variable is configured according to your input JSON or CSV file.
  * The name of the target column containing the text.
  * Default value is `annotations.intent.choices`.
  * The input format of the training data.
  * Default value is `ai_center`.
  * Supported values are: `ai_center` or `auto`.
  * If `ai_center` is selected, only `JSON` files are supported. Make sure to also change the value of the **dataset.target_column_name** to `annotations.sentiment.choices` if `ai_center` is selected.
  * If `auto` is selected, both `CoNLL` and `JSON` files are supported.
* **BOW.hyperparameter_search.enable**
  * The default value for this parameter is `True`. If left enabled, this will find the most performant model in the given timeframe and compute resources.
  * This will also generate a `HyperparameterSearch_report` PDF file to showcase variations of parameters that were tried.
* **BOW.hyperparameter_search.timeout**
  * The maximum time the hyperparameter search is allowed to run in seconds.
  * Default value is `1800`.
* **BOW.explain_inference**
  * When this is set to `True`, during inference time when model is served as ML Skill, some of the most important n-grams will also be returned along with the prediction.
  * Default value is `False`.
#### Optional variables
You can add other optional variables by clicking on the **Add new** button. However, if you set the **BOW.hyperparameter_search.enable** variable to `True`, the optimal values of these variables are searched. For the following optional parameters to be used by the model, please set the **BOW.hyperparameter_search.enable** search variable to `False`:
* **BOW.lr_kwargs.class_weight**
  * Supported values are: `balanced` or `None`.
* **BOW.ngram_range**
  * Range of sequence length of consecutive word sequence that can be considered as features for the model.
  * Make sure to follow this format: `(1, x)`, where `x` is the maximum sequence length you want to allow.
* **BOW.min_df**
  * Used to set the minimum number of occurrences of the n-gram in the dataset to be considered as a feature.
  * Recommended values are between `0` and `10`.
* **dataset.text_pp_remove_stop_words**
  * Used to configure whether or not stop words should be included in the search (for example, words like `the`, `or`).
  * Supported values are: `True` or `False`.
### Artifacts
The evaluation report is a PDF file containing the following information in a human-readable format:
* ngrams per class
* Precision-recall diagram
* Classification report
* Confusion matrix
* Best Model Parameters for Hyperparameter search
**ngrams per class**
This section contains the top 10 n-grams that affects the model prediction for that class. There is a different table for each class that the model was trained on.
**Precision recall diagram**
You can use this diagram and the table to check the precision, recall trade-off, along with f1-scores of the model. The thresholds and corresponding precision and recall values are also provided in a table below this diagram. This table will choose the desired threshold to configure in your workflow so as to decide when to send the data to **Action Center** for human in the loop. Note that the higher the chosen threshold, the higher the amount of data that gets routed to Action Center for human in the loop will be.
There is a precision-recall diagram for each class.
For an example of a precision-recall diagram, see the figure below.
![docs image](https://dev-assets.cms.uipath.com/assets/images/ai-center/ai-center-107206-992070d9.webp)
For an example of a precision-recall table, see the table below.
| Precision | Recall | Threshold |
| 0.8012232415902141 | 0.6735218508997429 | 0.30539842728983285 |
| 0.8505338078291815 | 0.6143958868894601 | 0.37825683923133907 |
| 0.9005524861878453 | 0.4190231362467866 | 0.6121292357073038 |
| 0.9514563106796117 | 0.2519280205655527 | 0.7916427288647211 |
**Classification report**
The classification report contains the following information:
* Label - the label part of the test set
* Precision - the accuracy of the prediction
* Recall - relevant instances that were retrieved
* F1 score - the geometric mean between precision and recall; you can use this score to compare two models
* Support - the number of times a certain label appears in the test set
For an example of a classification report, see the table below.
| Label | Precision | Recall | F1 Score | Support |
| 0.0 | 0.805 | 0.737 | 0.769 | 319 |
| 1.0 | 0.731 | 0.812 | 0.77 | 389 |
| 2.0 | 0.778 | 0.731 | 0.754 | 394 |
| 3.0 | 0.721 | 0.778 | 0.748 | 392 |
| 4.0 | 0.855 | 0.844 | 0.85 | 385 |
| 5.0 | 0.901 | 0.803 | 0.849 | 395 |
**Confusion Matrix**
![docs image](https://dev-assets.cms.uipath.com/assets/images/ai-center/ai-center-107350-e4988f34.webp)
**Best Model Parameters for Hyperparameter search**
When the **BOW.hyperparameter_search.enable** variable is set to `True` the best model parameters picked by the algorithm are displayed in this table. To retrain the model with different parameters not covered by the hyperparameter search you can also set these parameters manually in the **Environment variables**. For more information on this, check the [Environment variables](#environment-variables) section.
For an example of this report, see the table below.
| Name | Value |
| BOW.ngram_range | (1, 2) |
| BOW.min_df | 2 |
| BOW.lr_kwargs.class_weight | balanced |
| dataset.text_pp_remove_stop_words | True |
#### Hyperparameter search report
This report is a PDF file generated only if the **BOW.hyperparameter_search.enable** parameter is set to `True`. The report contains the best values for the optional variables and a diagram to display the results.
![docs image](https://dev-assets.cms.uipath.com/assets/images/ai-center/ai-center-107766-71483f85.webp)
#### JSON files
You can find separate JSON files corresponding to each section of the **Evaluation Report** PDF file. These JSON files are machine-readable and you can use them to pipe the model evaluation into Insights using the workflow.
### Data
#### Evaluation CSV file
This is a CSV file with predictions on the test set used for evaluation. This file also contains the n-grams that impacted the prediction (irrespective of the **BOW.explain_inference** variable value).
