# My notifications
> Personal notification preferences in Test Manager, accessible from the My Notifications view on the Notifications settings page.
You can manage your notifications using the **My Notification** view on the **Notifications** settings page. You access the **Notifications** settings page through the **Notification settings**![Notification settings icon](https://docs.uipath.com/api/binary/test-manager/2/592050/362809) icon on the **Notifications** panel or the **Preferences** menu option from your user account menu. Visit [Notification settings](https://docs.uipath.com/automation-suite/automation-suite/2024.10/admin-guide/about-notifications#notifications-settings-page) to learn more.
The following section describes how to view and manage your notifications in the **Notifications** panel and the **Notifications** settings, and the notification events you can subscribe to.
## Events
You can subscribe to the following events that are specific for testing:
1. **TestManager TestExecutions**
   - Events related to the state of a test execution.
   1. **TestExecution started** - The execution of a test set has started.
   2. **TestExecution cancelled** - The execution of a test set has been cancelled.
   3. **TestExecution finished** - The execution of a test set has been finished.
2. **ProjectMigrations** - Events related to the state of a project migration.
   1. **Project Import Completed** - The import process of a project is complete.
   2. **Project Export Completed** - The export process of a project is complete.
   3. **Project Import Failed** - The import process of a project failed.
   4. **Project Export Failed** - The export process of a project failed.
3. **File Export** - Events related to the exporting of test objects, such as requirements, test cases, and test sets.
   1. **File export completed** - The export of a test object was successful.
   2. **File export failed** - The export of a test object failed.
4. **Test cases** - Events related to the assignment of test case to users.
   1. **Test case assigned** - A test case was assigned to you.
   2. **Test case unassigned** - A test case was unassigned from you.
## Viewing and accessing notifications
You can access notifications through the **Notifications** panel only.
To access the **Notifications** panel, go to the top navigation bar and select the bell ![Bell icon](https://documentationpicturerepo.blob.core.windows.net/screenshots/screenshots/00_Action_Center_Automation_Cloud/bell_icon_notifications_panel.png) icon. The **Notifications** panel displays notifications ordered by date, in descending order. The **Notifications** panel displays notifications from newest to oldest.
To access a specific notification, select the desired notification frame.
### Filtering notifications
While you're in the **Notifications** panel, you can further filter the notifications, so you can view certain notifications first. To filter the notifications that you receive in the **Notifications** panel:
1. Open the **Notifications** panel.
2. Select the **Service** dropdown and then select the service for which you want to view notifications.
3. Select the **Severity** dropdown and then select the severity of the notifications that you want to view.
## Viewing and accessing email notifications
When an event that you are subscribed to takes place, an email notification is generated and sent to the email address that you used to create your account. To access the email notifications, check out the inbox of the email address where you know the notifications will be sent.
You can get the following information from the email:
* Read general information about the event that took place.
* Navigate to the corresponding service and tenant where the event took place.
Figure 1. Actionable notifications
## Displaying only unread notifications
To display unread notifications, select the **Unread only** checkbox in the **Notifications** panel.
## Marking all notifications as read
To mark all notifications as read:
* In the **Notifications** panel, select **More Action on All Notifications** at the bottom of the **Notifications panel** and then select **Mark all as read**.
## Clearing all notifications
To clear all notifications from the Notifications panel:
* In the **Notifications panel**, select **More Action on All Notifications** at the bottom of the **Notifications panel** and then select **Clear all**.
## Deleting notifications
You can delete notifications individually. To delete a notification:
1. Go to a notification from the **Notifications** panel and select **Action on Notification**.
2. Select **Delete**.
Selecting **Delete** permanently deletes a notification.
## Subscribing to events
You can subscribe to certain events to receive notifications about them. Subscribe to events in the **Notifications** settings page. Visit to learn more.
:::note
The **Automation Cloud** column is visible for services with in-app notifications enabled. The **Email** column is visible for services with email notifications enabled.
**Subscribing to an event:**
1. Go to the **Notifications** settings page.
2. Go to a service tab and then go to the **Automation Cloud** or **Email** column.
3. Select the checkbox that is inline with the event that you want to subscribe to.
   If you want to receive both in-app and email notifications on an event, then select both checkboxes under **Automation Cloud** and **Email** column.
### Subscribing to all events
3. Select the **Automation Cloud** or **Email** checkbox to subscribe to notifications on all events.
## Unsubscribing from events
To stop receiving notifications, you can unsubscribe from certain events. You can unsubscribe from events from the **Notifications** panel or from the **Notifications** settings page.
:::note
**Unsubscribing from the Notifications panel**:
1. Access the **Notifications** panel.
2. Go to a notification and select the **Action on Notification**![docs image](https://documentationpicturerepo.blob.core.windows.net/screenshots/screenshots/00_Action_Center_Automation_Cloud/vertical_ellipsis_notifications_panel_icon.png) menu.
3. Select **Unsubscribe from &lt;event&gt;.**
### Unsubscribing from the Notification settings page
1. Go to the **Notification** settings page.
2. Go to a service tab and then go to the **Automation Cloud** column.
3. Deselect the checkbox that is inline with the event that you want to unsubscribe from. If you want to unsubscribe from both in-app and email notifications for an event, then deselect both checkboxes under **Automation Cloud** and **Email**.
### Unsubscribing from all events
2. Go to a service tab and then go to the **AutomationCloud** or **Email** column.
3. Deselect the **Automation Cloud** or **Email** checkbox to unsubscribe from notifications about all events.
:::warning
Unsubscribing from all the events of a service, via both **Automation Cloud** and **Email**, generates the following warning: "You’re not subscribed to receive any notifications from this service."
The **Restore default subscriptions** option restores the default subscriptions for notifications received both on **Automation Cloud** and **Email**.
