# Defect synchronization
> Synchronize test execution results and defects with external ALM tools from Test Manager, including logs, screenshots, and attachments.
You can synchronize execution results with external tools, as part of the [Application Lifecycle Management tool integration](https://docs.uipath.com/test-manager/automation-suite/2024.10/user-guide/about-alm-tool-connectors). Information that is gathered during execution, such as results, logs, timestamps, and other details is synchronized with the tool that you have integrated with Test Manager.
Please note that at the moment there can be only one connection which is enabled for defect synchronization overall per project.
:::note
* To synchronize defects, you need to configure a
connector in Test Manager. See available connections in [Test Manager](https://docs.uipath.com/test-manager/automation-suite/2024.10/user-guide/about-alm-tool-connectors).
* You need to have [executed a test set first](https://docs.uipath.com/test-manager/automation-suite/2024.10/user-guide/executing-tests#executing-tests).
## Who can synchronize defects
All user roles aside from Read-only can synchronize defects.
For more information see [User and Group Access Management](https://docs.uipath.com/test-manager/automation-suite/2024.10/user-guide/managing-users-and-groups#user-and-group-access-management).
## Create defect
You can create defects when you access test case logs in the **Execution** page.
1. Navigate to **Execution**
2. Open a test result and the select the test case key to open the logs.
3. Select **Tasks** and select **Create Defect**.
   Figure 1. The **Tasks** dropdown list displaying the **Create Defect** action
   ![The Tasks dropdown list displaying the Create Defect action](https://docs.uipath.com/api/binary/test-manager/2/592050/463503)
The defect is created and synchronized with your external tool. You can open the defect directly in the tool (e.g., Atlassian Jira) by navigating to the test execution result that has a synchronized defect.
## Unlink defect
When you unlink defects from an external tool, the entry created in the tool remains unchanged. In Test Manager, the test execution result will not be linked with an external tool.
2. Open a test result and then select **Tasks**
3. Select **Unlink Defect**.
