# Azure DevOps
> Azure DevOps integration with Test Manager for synchronizing work items and supporting agile planning and defect tracking.
Integrate Azure DevOps to Test Manager to support your test management efforts, agile planning, or defect tracking. Through this integration, you can synchronize your work items to Test Manager.
To connect your Test Manager instance to an Azure DevOps project:
1. Create a Project in Azure DevOps
2. Configure an Azure DevOps Connection
## Prerequisites
* Azure DevOps account
* [Assign permissions to integrate with service hooks](https://docs.microsoft.com/en-us/azure/devops/service-hooks/overview?view=azure-devops#q-what-permissions-do-i-need-to-set-up-a-subscription)
* Test Manager administrator account
* [UiPath® Test Manager Azure DevOps Extension](https://marketplace.visualstudio.com/items?itemName=uipath.tmh-connector)
* [Azure Test Plans](https://azure.microsoft.com/en-us/products/devops/test-plans/) - to sync test items with your Test Manager. Make sure to validate the integration scenario thoroughly. Consider the following limitations:
  * Assertions cannot be synchronized.
  * Manual test steps cannot be synchronized. Azure DevOps stores test steps in an XML field (`Microsoft.VSTS.TCM.Steps`) that its REST APIs don't expose as structured data — this is an Azure DevOps API constraint, not a Test Manager limitation.
  * Test Executions cannot be set to status Completed, since they get locked in Azure DevOps, for results to be synchronized in parallel.
  * The scope of projects in Test Manager and Azure DevOps is substantially different and, therefore, requires detailed planning of object routing.
## Create a Project in Azure DevOps
1. Log in to Azure DevOps.
2. Click **Create new project** and configure your project settings:
   * **Project name**: Enter a name for your project.
   * **Description**: Add a description to help you easily identify the use of each project.
   * **Version control**: Choose your version control.
   * **Work item process**: Select **Agile** from the dropdown as your default process to support your Agile planning methods, including development and test activities.
3. Click **Create**.
   Your project is added to your collection.
   ![docs image](https://docs.uipath.com/api/binary/test-manager/2/592050/125618)
## Configure an Azure DevOps Connection
**Prerequisites**: To save the UiPath® Test Manager extension on Azure DevOps, you must be an Azure **Administrator** user.
1. Log in to Test Manager as an administrator.
2. Open your project.
3. Navigate to **Project Settings** &gt; **Integration**.
4. Click **New Connection** and select **Azure DevOps** from the dropdown.
5. Configure the following connection settings:
   * **Name**: Enter a name for your Azure DevOps connection.
   * **Description** (Optional): Add a description for reference.
   * **Server URL**: Add the Azure Dev Ops server URL. For example: `https://company-name-serverRegion.cloudapp.azure.com`.
   * **Personal Access Token**: Create a PAT and paste it into this field to authorize Test Manager to perform actions.
     :::warning
     When you create the Azure DevOps connection, the PAT needs to have full access to Azure DevOps services. To do this, select **Full access** under **Scopes**, when you create or edit a PAT. After the connection is finished, you can reduce the PAT scopes to : **Test Management** - `Read & Write`, and **Work Items** - `Read & Write`. For more information, see [Use personal access tokens](https://learn.microsoft.com/en-us/azure/devops/organizations/accounts/use-personal-access-tokens-to-authenticate?view=azure-devops&tabs=Windows).
   * **Defect Type**: Enter an object type used for bug reporting in Azure DevOps. Otherwise, leave empty if you do not want to use defect integration.
     Enter a defect type based on what object type you have selected for your newly created Azure DevOps project. For example: `Bug` or `Issue`.
   * **Project Name**: Enter your Azure DevOps project name.
     ![docs image](https://docs.uipath.com/api/binary/test-manager/2/592050/126414)
6. Click the connection to expand the panel and copy the **API Key** for later use.
7. Open your project in Azure Dev Ops and go to **Project settings**.
8. Under **Extensions**, go to **UiPath® Test Manager**.
9. Configure the following extension settings:
   * **Requirement Types**: Select the types of objects you want to assign a test to. These will show up as requirements in Test Manager. For more information, see [Requirements](https://docs.uipath.com/test-manager/automation-suite/2024.10/user-guide/requirements#requirements).
   * **Server URL**: Add the Test Manager URL. The URL should have the following format: https://{yourDomain}/{organizationName}/{tenantName}/testmanager_.
   * **API**: Paste the API key.
   * **Manage Tests with Azure DevOps**: Select this option to manage your tests through Azure DevOps. Otherwise, leave this option off, to manage your tests through Test Manager.
10. Click **Save**.
    ![docs image](https://docs.uipath.com/api/binary/test-manager/2/592050/126380)
## Working With Azure DevOps Integration
To take a look at how the integration works, consider the following examples:
* [Synchronizing Work Items](https://docs.uipath.com/test-manager/automation-suite/2024.10/user-guide/connecting-an-azure-devops-project#azure-devops)
* [Managing Tests via Azure DevOps](https://docs.uipath.com/test-manager/automation-suite/2024.10/user-guide/connecting-an-azure-devops-project#azure-devops)
## Synchronizing Work Items
You can create work items (e.g. Epic) in Azure DevOps and synchronize them with Test Manager. The work items will show up on the **Requirements** page.
1. Log in to Azure DevOps and open your project.
2. Click the plus button and select a **New work item** from the dropdown.
3. Configure your work item and then click **Save & Close**. For more information, see [Add and update a work item](https://docs.microsoft.com/en-us/azure/devops/boards/backlogs/add-work-items?view=azure-devops&tabs=browser).
4. Log in to Test Manager and go to **Requirements** to view the synchronized work item. To refresh the page, click the **Requirements** breadcrumb element.
   :::note
   To synchronize work items created before the integration, open an individual item, click the **Actions** button, and select **Push to Test Manager** from the dropdown.
## Managing Tests Via Azure DevOps
You can use Test Cloud for test automation and Azure DevOps for test management. To use both solutions together, first you need to select **Manage Tests with Azure DevOps** in the integration configuration. For more information, see [Configure an Azure DevOps Connection](https://docs.uipath.com/test-manager/automation-suite/2024.10/user-guide/connecting-an-azure-devops-project#configure-an-azure-devops-connection).
Now, you can manage the tests by pushing test cases from Azure DevOps to Test Manager. In other words, any Azure work item of type Test Case is going to be pushed to Test Manager. Make sure to add test cases to your Azure test plans, as this is where the results are going to be pushed to. For more information, see [Create test plans and test suites](https://docs.microsoft.com/en-us/azure/devops/test/create-a-test-plan?view=azure-devops).
Following this synchronization, you can automate the test cases through Studio. Subsequently, if you [execute your test cases using Orchestrator](https://docs.uipath.com/orchestrator/automation-suite/2024.10/user-guide/test-executions), the results are pushed to your Azure test plans.
## Azure DevOps Data Flow Matrix
The following table summarizes what data synchronizes between Azure DevOps and Test Manager through the native UiPath Azure DevOps extension, and in which direction. This matrix does not apply to [Test Manager Connect](https://docs.uipath.com/test-manager/automation-suite/2024.10/user-guide/uipath-test-manager-connect), which uses a separate synchronization mechanism through Planview® Hub.
| Azure DevOps object / data | Direction | Sync mechanism | Notes / limitations |
| Work items (Epic, User Story, etc.) | Azure DevOps → Test Manager | Automatic on save; appears on the **Requirements** page | Items created before the integration need a manual **Push to Test Manager** action |
| Test Case work item | Azure DevOps → Test Manager | Requires **Manage Tests with Azure DevOps** to be enabled in the connection | Must be added to an Azure Test Plan, or execution results have nowhere to sync back to |
| Manual test steps (`Microsoft.VSTS.TCM.Steps` field) | Not synchronized | — | Azure DevOps stores test steps as an XML field its REST APIs don't expose as structured data — an Azure DevOps API constraint, not a Test Manager limitation |
| Assertions | Not synchronized | — | Cannot be synchronized, per the Azure Test Plans prerequisite |
| Test execution results | Test Manager/Orchestrator → Azure DevOps Test Plans | Automated executions run through Orchestrator and push results to the linked Azure Test Plan | Executions can't be set to Completed in Azure DevOps — they stay unlocked so results can keep syncing in parallel |
| Defects | Test Manager → Azure DevOps | Created manually from Execution page logs (**Create Defect**) | Only one connector per project can be enabled for defect sync at a time |
## Managing Azure DevOps Connections
The following table lists the actions that you can take to manage your Azure DevOps connections.
 <colgroup>
  <col/>
  <col/>
  <col/>
 </colgroup>
     Action
     Procedure
    Edit
     Edit your connection settings.
         Log in to the Test Manager as an administrator.
         Open your project.
         Click the Settings button to open Project Settings.
         In the Integration list, click an Azure DevOps connection to expand the panel.
         Click Edit to configure the connection.
         Click Save to confirm.
    Delete
     Delete the selected connection and its associated requirements.
         Open your project.
         Click Delete to remove the connection.
         Click Ok to confirm.
## Related articles
[Defect synchronization](https://docs.uipath.com/test-manager/automation-suite/2024.10/user-guide/defect-synchronization#defect-synchronization)
