# Licensing Test Manager
> For Test Manager to work, within the context of Test Suite™, you need the following license types:
* **Platform**: offers Test Manager as a service within your organization.
* **Tester - Named User**: allows a user to utilize Test Manager. Every individual user requires a separate license. For example, if your team has 10 users, each of them will require their own license, meaning you will need a total of 10 licenses.
## Platform license
You need a **Platform** license to enable the Test Manager service within your organization.
To check if you have a **Platform** license that includes Test Manager:
1. Navigate to the **Admin** tab.
2. Select **Licenses**.
3. Go to the **Robots & services** tab.
If you already have a **Platform** license, that includes Test Manager, then you can perform the following steps for enabling Test Manager in your organization and tenant:
2. Select the tenant for which you want to enable Test Manager.
3. Go to **Services**.
4. Select **Add Services** and then select **Test Manager**.
## Tester - Named User license
After you enable the Test Manager service on a tenant, you additionally need to allocate the **Tester - Named User** licenses to all users who should use Test Manager. The **Tester - Named User** license functionality can come bundled into other user licenses, such as the **Automation Developer - Named User** bundle, which allows you to create tests in Studio, and then manage them in Test Manager.
To allocate **Tester - Named User** licenses:
1. Navigate to the **Admin**, and go to **Licenses**.
2. Go to the **Users** tab.
3. In the **View Licenses** section, check how many **Tester - Named User** licenses are available for your organization.
4. Depending on how you want to allocate licenses (for user or for a group of users), perform the following steps:
   * For users:
     1. Expand the **License Allocations to Users** section.
     2. For the desired user, select **Edit license allocation**.
     3. Select **Tester - Named User**.
     4. Select **Save** to confirm the license allocation.
   * For a group of users:
     2. For the desired group, select **Edit group allocation rule**.
To manage your organization's licenses, visit [Allocating user licenses](https://docs.uipath.com/automation-suite/automation-suite/2023.4/admin-guide/allocating-user-licenses).
## Planview Hub
UiPath Test Manager Connect licenses, provided by Planview, come bundled with your Test Manager platform license.
You can download the on-premises version of UiPath Test Manager Connect from the UiPath Customer Portal. An on-premises license key comes with your Test Manager platform license.
