# Users and Groups
> As an Organization Administrator, you can manage user and group access to Test Manager projects. This role is independent of any role assignment.
## Conditions
:::important
Access management works with Orchestrator version 2021.10 or higher.
* Organization Administrator is set by default as **Project owner** on all projects.
* Access to Test Manager privileges is granted only by the Organization Administrator or the **Project owner**, by assigning users and roles to the project.
* You can transfer project ownership to another user only if you are an Organization Administrator or a **Project owner**.
* Users that are signed in cannot be removed until they sign out.
## Enable access management
To manage users and groups, you need to enable access management in your Test Manager project. Open Test Manager and navigate to **Project Settings** &gt; **Manage access**, open a project, click **Enable now**, and then confirm your action. Now you can start assigning users and groups to your organization's projects.
![docs image](https://dev-assets.cms.uipath.com/assets/images/test-manager/test-manager-125666-1f4b0c54.webp)
## Assign Users and Groups
If you have [enabled access management](managing-users-and-groups.md), you can start assigning users and groups to your project.
1. Sign in to Test Manager.
2. Open a project.
3. Navigate to **Project Settings** &gt; **Manage Access**.
4. Click **Assign users/groups**.
5. Enter a user or group in the form field.
6. Press **Enter** to add the user/group. You can add multiple users and groups at once.
7. Click **Add** to confirm your action. The users and groups are now assigned to the project.
   ![docs image](https://dev-assets.cms.uipath.com/assets/images/test-manager/test-manager-126870-e41dca16.webp)
## Transfer Project Ownership
As **Project owner**, you can transfer this role to another user. The new user can grant Test Manager access to users and groups, and perform administrative tasks.
2. Open a project.
4. Find the user to which you want to transfer project ownership and click the vertical ellipsis.
5. Select **Transfer ownership** in the dropdown list.
6. Confirm your action. Project ownership is now transferred to the new user.
## Remove Individual User and Groups
2. Open a project.
4. Find the user or group that you want to remove and click the vertical ellipsis.
5. Select **Remove user** or **Remove group** in the dropdown list.
To perform a bulk operation, see [Removing users and groups](bulk-operations.md).
**Troubleshooting Access Management**
Users that have been disabled receive the following message:
![docs image](https://dev-assets.cms.uipath.com/assets/images/test-manager/test-manager-127271-98d345f3.webp)
To solve this issue, the user can request access, followed by approval by the Test Manager administrator.
## Behavior of unlicensed users
Users invited to an organization without a **Tester - Named User** license can still explore Test Manager projects where they hold the **Viewer** role. Unlicensed users who hold the **Viewer** role in a project can perform the following actions:
* Open the project.
* Review and navigate through test objects, such as:
  * Requirements
  * Test Cases
  * Test Sets
* Go to the **Execution** tab and view the list of grouped executions by **Test Set**.
  :::note
  Users who don't have a **Tester - Named User** license cannot open a test execution and view its details.
