# Users and Groups
> Manage the list of users and roles who have access to Test Manager.
## Conditions
To receive emails about user access authorizations, you need to configure [email notifications](application-settings.md).
## User Roles and Privileges
Test Manager supports two roles: Administrator and User. You can assign one of these roles to your users. The following table lists the privileges of each role.
| Privileges | Administrator | User |
| Read, update and delete objects within any project | ✅ | ✅ |
| Create projects | ✅ | ❌ |
| Activate/deactivate users | ✅ | ❌ |
| Access to maintenance tasks | ✅ | ❌ |
| Access to application settings | ✅ | ❌ |
| Access project settings and the administration section | ✅ | ❌ |
## User Access Management
As an administrator, you can manage users by authorizing, rejecting, disabling, and editing access to Test Manager.
If you are an Orchestrator admin and you log in for the first time in Test Manager, you inherit the administrator.
To create a Test Manager user, you need to [add a local user in Orchestrator](https://docs.uipath.com/orchestrator/standalone/2021.10/user-guide/managing-users#adding-a-user-account). The user will log in to Test Manager, and be requested to change the password.
## Manage User Access
To manage user access, open Test Manager, click the ![docs image](https://dev-assets.cms.uipath.com/assets/images/test-manager/test-manager-more_vertical_button.png-881c48d9.webp) vertical ellipsis at the upper-right corner of the page and select **Users and Groups**.
![docs image](https://dev-assets.cms.uipath.com/assets/images/test-manager/test-manager-126851-e9322a8f.webp)
The following table lists the actions that you can take to manage your users.
<colgroup>
<col/>
<col/>
<col/>
</colgroup>
Action
Procedure
Authorize/Reject
Authorize access to users that have requested it through the login page. Authorizing a user request sets their status as Active. Correspondingly, rejecting a user request sets their status as Disabled.
To keep yourself up-to-date with user access requests and authorizations, you need to configure Email Notifications.
In the Users and Groups page, go to Pending Authorization.
Select a user and click the  vertical ellipsis button to open the dropdown menu.
Select Authorize or Disable.
Disable
Disable user access to Test Manager. The user status is set to Disabled and its entry is moved to the Disabled tab.
In the Users and Groups page, go to one of the user tabs (All, Users, Administrators).
Click Disable.
Update
Update user roles to Admin or User.
Click a username.
Click the Admin Role toggle to switch it on or off.
Click Save.
## Troubleshooting Access Management
Users that have been disabled receive the following message:
![docs image](https://dev-assets.cms.uipath.com/assets/images/test-manager/test-manager-127271-98d345f3.webp)
To solve this issue, the user can request access, followed by approval by the Test Manager administrator.
