# SAP Solution Manager integration
> SAP Solution Manager 7.2 SP08 and later integration with the UiPath toolset for creating, executing, and managing test cases across SAP and non-SAP applications.
SAP Solution Manager 7.2 SP08 and newer versions can be integrated with the UiPath® toolset. Through this integration, you can create automated test cases across the enterprise including SAP and non-SAP applications.
SAP customers can execute test cases, exchange the complex test data, and ensure the functionality of the Business Process Change Analyzer with TBOM Recording for automation projects. Additionally, you have access to accurate reporting with a consolidated view.
:::note
When using Test Manager versions 2022.10 and lower, the SAP Solution Manager Integration is available only with Studio versions 2022.10 and lower. :::
## Process Flow Chart
The following flow chart represents the UiPath® integration with SAP Solution Manager.
![UiPath integration with SAP Solution Manager process flow chart](https://dev-assets.cms.uipath.com/assets/images/test-manager/test-manager-docs-image-125806-91e1db1a-d6485a35.webp)
The process flow chart contains the following components:
* Test Manager: Ensures test execution, log collector, and test data transfer SAP Solution Manager.
* Orchestrator: Manages test case execution.
* Robot: Performs test executions. The Robot is connected to SAP WinGUI and automates SUT (e.g. SAP S/4 HANA)
The flow is done through the following steps:
1. Creation of a test case from SAP Solution Manager to UiPath® Studio.
2. Test case publishing to Orchestrator.
3. Test case execution through Test Manager.
4. Test executed managed through the Orchestrator and performed by the Robots.
5. Results transferred from Orchestrator to Test Manager, and then SAP Solution Manager.
6. Business Process Change Analyzer with TBOM Recording for automation projects.
