# Create test cases
> Create test cases in Test Manager to build your testing portfolio, then add manual steps or assign automation to each case.
To start building your testing portfolio, create a test case in Test Manager. You can later [provide manual steps](https://docs.uipath.com/test-manager/automation-suite/2.2510/user-guide/manual-test-cases#manual-test-cases) or [assign automation](https://docs.uipath.com/test-manager/automation-suite/2.2510/user-guide/automate-test-cases#automate-test-cases).
1. Open your project in Test Manager. If you do not have a project yet, see [Creating a Project](https://docs.uipath.com/test-manager/automation-suite/2.2510/user-guide/getting-started-test-manager#creating-a-project).
2. In the left navigation panel, go to **Test Cases**.
3. Select **Create Test Case**.
   ![Create Test Case button in Test Manager Test Cases section](https://dev-assets.cms.uipath.com/assets/images/test-manager/test-manager-docs-image-126445-edc9d406-382c1055.webp)
4. Configure the test case:
   * **Name** - Enter a name for your test case.
   * **Version** - (Optional) Add a version tag to the test case.
   * **Description** - (Optional) Enter a description for the test case. To add formatted text, you can use the Markdown syntax.
   * **Labels** - Add any number of custom labels.
     ![Create Test Case form with Name, Version, Description, and Labels fields](https://dev-assets.cms.uipath.com/assets/images/test-manager/test-manager-docs-image-125686-906e8704-662a2978.webp)
5. Select **Create** to confirm. The test case is created and displayed on the **Test Cases** page.
   :::tip
   * [Assign test cases to requirements](https://docs.uipath.com/test-manager/automation-suite/2.2510/user-guide/assigning-test-cases-to-requirements)
   * [Link test cases to requirements](https://docs.uipath.com/test-manager/automation-suite/2.2510/user-guide/managing-test-cases)
   * [Upload documents](https://docs.uipath.com/test-manager/automation-suite/2.2510/user-guide/test-manager-managing-documents)
## Result
